Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 08-30-2008, 04:54 PM   #1
makita single blade planer
i have a makita single blade planer that I would like to get information on. It appears to be a tool that cuts a veneer off the stock to either use the veneer or plane a board. Does anyone have information on how to use it or has anyone used one? Thanks Larry
lalkie is offline   Reply With Quote
Old 08-30-2008, 05:00 PM   #2
the Musigician
DangerMouse's Avatar
best bet is to google-yahoo or whatever search engine you prefer the name and MODEL NUMBER of the tool, you will no doubt find info, reviews, owners manuals, makita's website pages on this tool, etc. send us back a link? i'd like to see this tool.
DM
Old 08-30-2008, 05:02 PM   #3
Moderator
Termite's Avatar
Larry, I moved your post over here to the tools section.
A handheld power planer is designed for removal of stock off the edge or face of boards. It isn't going to cut off a usable veneer, just chips. Common uses for a tool like this include planing the edges of doors, scribing cabinets to walls, and a number of woodworking uses.
Old 08-31-2008, 07:29 PM   #4
This is not a hand held machine. it is a 250 pound machine on wheels that feeds the material through the blade on a belt. i was looking for someone that had experience with this machine to help me figure the best way to use it. i appreciate you moving the machine to the tool section i apparently missed this section. larry
Old 09-01-2008, 07:20 PM   #5
i will try an send a picture in the next few days. it is a machine that generally sold only in japan and aparently priced about $1100.00 used. i can't seem to get it working correctly. Larry
Old 09-01-2008, 07:32 PM   #6
the Musigician
thanks, i'm real curious to see it.
DM
and what's the problem with it?
Old 09-01-2008, 07:35 PM   #7
Moderator
Termite's Avatar
Sounds like an industrial planer. I've never seen a Makita version! Would love to see a picture.
Old 09-01-2008, 09:37 PM   #8
BUILDER / REMODELING CONT
buletbob's Avatar
I think he's talking about a thickness planer. I have a delta 220 model. But mine has three blades. I cant not envision a single blade pulling a usable piece of veneer from a board with out it breaking it. BOB
Old 09-02-2008, 07:48 AM   #9
the Musigician
most t-planers i've used (mine is a 13" rigid) have at least 2 blades. never seen a single blade planer b4. this is why i'm curious.
DM
Old 01-26-2009, 10:06 PM   #10
Go to you tube and type in makita precision planer. There is a video of what it does. I have not been able to get mine to work or been able to contaact the person that has one. The machine runs and works but won't feed the wood through. Any help would be appreciated. Thanks Larry
Old 01-27-2009, 05:58 AM   #11
the Musigician
if it's set up the way a standard planer is, then you have rubber rollers under there to drag the wood through. if they do not turn, wood do not go. are they turning?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 01-27-2009, 11:52 AM   #12
I just watched the videos on youtube and it almost looks like the blade doesn't spin like a normal thickness planer but instead the belt feeds the material against a stationary blade that planes a thin strip of wood off. Kinda like a manual hand planer with a belt under it to move the material across the blade.
If it is not carrying the wood threw the machine and the belt is moving. I would assume that the board is getting wedged somehow, not enough clearance for the wood to go threw the machine. From the videos it looks like it only takes a very very thin sliver off. Try raising the planer up and see if the board gets carried threw without taking anything off. If it does try lowering it little by little and see if you can get it to carry the board threw.
ponch37300 is offline   Reply With Quote
Old 01-29-2009, 08:56 PM   #13
The motor and belt seems to work fine. The board does not seem have enough traction on hte belt in order to be moved through the blade. I have tried limiting the cutting to the minimum cut possible. It still won't feed the board through. The blade seems sharp. I have tried 2x4" and ceder pickets without luck.
any help would be appreciated. Larry
Old 01-31-2009, 10:26 AM   #14
Is the belt wore out? From the videos it doesn't seem like there is many things to make the board go threw the machine. Maybe try to google it and try and get an owners manual.
Old 01-31-2009, 10:38 AM   #15
the Musigician
being on dialup, i can't see the video, but if it's a slow moving roller that grips the wood, then there needs to be grip and torque to push it through the blade. if torque, then the belt-drive is not doing it's job, if grip, then the rollers are not adjusted correctly. purely hypothetical, of course, not seeing what you have. are either adjustable? belt or roller tension?
DM
Separate Single Pole Switches for Ceiling Fan Light and Fan Only estatehomes Electrical 19 01-13-2012 07:13 PM
Delta table saw blade guard problem RDS Tools 7 03-07-2008 04:29 PM
Feeding multiple subpanels with a single generator monsoon Electrical 8 10-02-2007 05:25 PM
Makita from China? Bullmoose Tools 11 08-20-2007 10:08 AM
Circular Saw Blade Recommendation allen1466 Tools 7 06-07-2006 07:58 AM
