-   Tools (http://www.diychatroom.com/f29/)
-   -   Makita new miter saw two rail system flawed? (http://www.diychatroom.com/f29/makita-new-miter-saw-two-rail-system-flawed-49358/)
nickdu 07-21-2009 06:01 PM
First of all I'm a total newbie when it comes to any kind of carpentry. I also found an existing makita ls1016l thread, but most, if not all, replies were unrelated to the product itself so I thought I would create a new thread.
I just purchased the makita ls1016l. I tried it out a few times and the results are not good. I'm trying to figure out if it's me or the saw. The carriage slides very easy on the bottom rails. Sliding on the top rails is much more difficult compared to the bottom rails. The result, at least for me, is that when slide cutting the carriage stops momentarily when I reach the point where I need to start sliding on the top rails. This causes marks in the cut.
Am I doing something wrong, or is this two rail system flawed? It seems to me that one set of rails will produce a constant sliding mechanism and thus produce better cuts, but what do I know.
Thanks,
Nick
Five Star 07-22-2009 09:23 PM
there is a knob @ the right side @ the rails that losens the rail, and there is a lever next to the front know that releases the bottom rails!!
this system is actually very good but takes some getting use too!
Thi saw preforms top knotch very smooth and the soft start motor is awsome!! im glad i waited i almost bought a kapex for $1300 + acessories
read the owners manuel or it could be that something was damaged at shipping! you got 30 days to return!:thumbsup:
nickdu 07-23-2009 09:30 AM
Thanks. I did read the entire manual. Both the stopper lever and the screw which adjust the upper rails are set such that the rails should move smoothly. I ended up returning the saw yesterday. I purchased a different brand.
Thanks,
Nick
Five Star 07-23-2009 07:47 PM
3 Attachment(s)
i think your making a mistake on that return, this saw is direct compitition to the most expensive mitersaw on the market today, The festool kapex!
and so far the only flaw i see is the fences need to be removed for beveled cuts, the cutting hieght could of been increased a 1/2"
Clutchcargo 07-23-2009 08:02 PM
63 Attachment(s)
Is the purpose of the top rail... to extend the cut to 16"? ls1016L
I've got the old model and love it.
Edit: no that's not it, same as mine 12" capacity. It's for a more compact design.
For that much money, I think I want a digital readout as on the Hitachi.
Five Star 07-23-2009 08:22 PM
it is a bit much for a 10" slider...but i had Hd mastercard pionts that equaled $300+ 400 i got for a old dewalt i sold on craigslist, so for me it was this or the $1300 kapex....and for 30 refund..i figured id give her a try!!
so far its VERY VERY SMOOOTH SAW ALL AROUND AND OPERATING!! im liking all about it! its hard to find a flaw..so im holding onto it for another 2weeks or 3 :thumbsup:
PaliBob 07-26-2009 04:15 AM
Originally Posted by Five Star (Post 305933)
........and so far the only flaw i see is the fences need to be removed for beveled cuts.....
Five Star I don't have the Makita, but don't the fences slide out for beveled cuts?
Five Star 07-26-2009 09:25 AM
Pali, the fences do slide for bevel cuts, but when the saw is tilted all the way to 45 degrees they need to come off becuase they go pass there locking piont!
PaliBob 07-26-2009 11:51 AM
Thanks, that is a sore point against Makita.
Thurman 07-26-2009 04:22 PM
nickdu - -I can't help but wonder if you might be having a similar problem as someone who posted about two months ago with a problem using a compound miter saw. The end result of that situation was that the user was pulling the handle of the saw straight down no matter where the angle on the saw was set to cut. The user was not pulling the handle in the direction the plane of the blade was traveling, therefore he was getting some weird edges to his cuts. You stated yourself that you were "a total newbie when it comes to any kind of carpentry." So, this may be something to look at, which direction are you actually pulling the handle when you make the cut--pulling straight down or pulling in the actual direction of the cut. Good Luck, David
nickdu 07-26-2009 06:48 PM
Yes, I'm definitely a total newbie at this. This was my first miter saw. Though I would like to think that I wouldn't pull the saw straight down for a bevel cut. At any rate, the cut I was making was a straight cut, no miter no bevel.
Thanks,
Nick
Legit 08-05-2009 04:37 PM
I have been using a Makita Miter saw for a while, and when this new dual slide miter saw came out, I had to get one! And with great results, i able to build, chop, miter, bevel all types of material with ease!
Especially for crown molding!
PaliBob 08-05-2009 05:59 PM
1 Attachment(s)
Originally Posted by Legit (Post 310973)
...... I had to get one! And with great results, i able to build, chop, miter, bevel all types of material with ease!
Legit, welcome to the forum
That's nice saw.
Do you have the same problem as Five Star as to having to remove the fence for 45 deg bevels?
The only other criticism (besides the OP) that I have heard on the 1016 is all the sawdust. Makita is supposed to have a new attachment for the 1016 called a "Dust Box" that so far is not available Do you have any dust complaints?
lairdness 08-08-2009 11:59 PM
I went with the LS1013 after serious amounts of hands on research. It was on sale at the h. depot for $400 (I think). THe fence isn't high so I fashioned one out of some nice stable 3/4 boards and added an aftermarket laser...the results is an insanely stable and accurate rig. I can easily split a pencil mark every time The saw itself is a work of art in my opinion...really quite beautiful. And it's nearly impossible to get the arm to flex, unlike the dewalts, craftmans, ridgids you name it...way better than all others in that price range and even way higher....I frigin LOVE my saw...one of my best investments ever. It even comes with a pretty nice blade.
PS looks like the 1016 has more or less the same lousy dust collection...I us an old hepa vac with a hose and it gets maybe 80%. That is prob in large part due to my fence with no v notch in it. But, it will cut 4x stock with one pass because of the lame rubber dust colector....so I'm fond of it myself.
PaliBob 08-09-2009 12:44 AM
lairdness, Welcome to the forum
You sound like a tool geek that knows what he is talking about.
I learn something new here every week. Thanks for sharing.
