Makita Grinder - Tools - DIY Chatroom Home Improvement Forum
Old 09-05-2009, 12:08 PM   #1
rws
Makita Grinder
I have an older Makita 5" Disc Grinder model 9505BH. I'm going to be doing some tile work with my son and I wanted to use a diamond blade in it. I'm not sure that's possible because of the recessed nut on the shaft. IOW, the blades it normally uses are not flat. Can I use a flat blade in this tool? Have any of you done that?
Thks,
Russ
rws is offline   Reply With Quote
Old 09-06-2009, 01:13 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Makita Grinder
Thks,
Russ
you just need to change the locknut
http://www.toolup.com/makita/193465-4.html
Mr Chips is offline   Reply With Quote
Old 09-06-2009, 01:22 AM   #3
rws
Makita Grinder
Mr. Chips,
That's what I need! Thank you very much.
Russ
Makita new miter saw two rail system flawed? nickdu Tools 18 01-19-2010 08:34 AM
Makita bhp451 vs Makita bhp454 SeaOfRed75 Tools 1 03-04-2009 05:36 PM
Grinder pump odor - venting issue? dadruz Plumbing 2 01-12-2009 10:17 AM
Makita from China? Bullmoose Tools 11 08-20-2007 10:08 AM
Grinder Help...big time HomeImprover Tools 5 05-19-2007 04:15 PM
