Makita Compound Saw Help - Tools - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 01:36 PM   #1
makita compound saw help
I have a Makita sliding compound saw LS1016L. The blade is out of alignment. I have been trying to align it by rotating the adjusting bolts in the back of the saw but nothing seems to saw get the blade to cut square. I think that the bevel is the problem but not sure. The owner's manual doesn't provide me with the clear instruction I need to make the adjustment. Any suggestions?
Jim
brevanskc is offline   Reply With Quote
Old 02-04-2012, 05:56 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,060
your dead stops might be off.
try this link, it shows how to tune just about every current mitre saw on the market
Miter Saw Tune-Up - THISisCarpentry
woodworkbykirk is offline   Reply With Quote
Old 02-04-2012, 06:09 PM   #3
Rewards Points: 13,300
Should be as simple as setting a speed square againt the blade (making sure it's not againt the teeth) and adjusting the stops with a couple of wrenches and a phillips screw driver on the plastic indicaters.
Review: Makita LS1016L Compound Sliding Mitre Saw and Makita 2704 Table Saw w/ Stand wnabcptrNH Tools 6 02-21-2010 07:52 PM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 11:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Suitable Miter Saw stand for 10" Sliding Makita compound saw zappy Carpentry 3 07-16-2008 08:33 PM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 09:22 AM
