Makita Blue Or White - Tools - DIY Chatroom Home Improvement Forum
Old 03-24-2011, 12:35 PM   #1
jad
Makita blue or white
What is the difference between the blue/green color and the white on the Makita. Looking at some battery drills and the big box store has a set of the whites for around $225. It is a 18v lithium
Seems to be a pretty deal if you compare what it cost to bye the two tools impact driver and 1/2" drill/driver separately.
thanks
jad is offline   Reply With Quote
Old 03-27-2011, 03:33 AM   #2
Rewards Points: 150
The blue tools have the 3.0 amp hr batt's and four pole "forever motors". The white tools have 1.5 amp hr batteries and plain old 2 pole "Serviceable" motors....
I cant speak for the "brushless" four pole makita drill or driver but I've used a 10.8V white and black set before, and they where solid tools that would take a drop from a 6' ladder and still run 3" screws till the cows came home............Good stuff
STL B. is offline   Reply With Quote
SW White Recommendations Please Ruby2 Painting 3 03-09-2011 07:56 AM
Should I replace my blue board after it got wet from a water heater leak? petep Drywall & Plaster 4 07-11-2010 10:44 PM
White Pine Hard-Wood floors? MrShadetree0222 Flooring 9 11-04-2008 09:24 AM
Trim - White or off-white? hellothere123 Painting 7 10-31-2008 12:29 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
