Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 01-16-2013, 10:03 PM   #1
Makita 9557NB 4.5" Angle Grinder - does it have a hard case?
I have a Makita 4.5" angle grinder model 9557NB. I noticed some Makita grinder comes with an aluminum case some with hard plastic case some with nylon bag.
Is there a hard case that would fit this particular grinder?
miamicuse is offline   Reply With Quote
Old 01-16-2013, 11:33 PM   #2
Will the aluminum case of the Makita 9557PBX1 grinder works with the 9557NB?
They are both 9557 series, and they are both 10-5/8" in length.
Old 01-17-2013, 01:12 AM   #3
I don't know, but if you look up "closed cell foam," that is the stuff you can use to make a form-fitting pad for a tool. You can make your own hard case for just about anything if you need to.
jeffsw6 is offline   Reply With Quote
Old 01-17-2013, 04:37 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
depends on the model number.. most of the bigbox stores get the same tool but packaged differently.. one store gets it with a hard case.. someone else with a bag.. sometimes the tool comes bundled with a different tool
woodworkbykirk is offline   Reply With Quote
Old 01-17-2013, 05:10 PM   #5
Am I the only one that hates when tools come in a bag?
Old 01-17-2013, 07:46 PM   #6
it depends on the tool, drills i prefer in a case it no only protects the tool and keeps it from bouncing around so the trigger gets pinned so it runs but also gives slots for storing bits.. nailers could care less i carry 6 nail guns so i keep em all in one container to save space
Old 01-17-2013, 09:53 PM   #7
No. I hate bags.
I like to put all my tools away in their boxes and sit them up. The bags make it impossible to organize them the way I like it.
cutting cementboard with 4.5" grinder diamond blade amakarevic Flooring 4 02-21-2012 08:37 PM
Hard time finding angle valve for toilet Repairtag General Discussion 14 01-02-2012 10:16 AM
angle grinder question itin1200 Tools 8 07-13-2010 08:07 PM
Is it wise to tuck point with an angle grinder? jpearson311 General Discussion 5 12-30-2009 07:54 AM
4" Angle Grinder trout_baller Tools 9 08-11-2007 09:47 PM
