Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 07-17-2009, 09:42 AM   #1
Makita 4301BV jig saw - what kind of blades do I need?
I just bought a used Makita 4301BV jig saw on ebay. The new Bosch T-shank blades that I just bought at Lowes don't fit. To my (untrained) eye, it doesn't look like U-shank would, either (but don't have any to try). Does this model use special Makita blades, or.. ?
A Google search didn't help me on this one...
Thanks!
Pickngrin is offline   Reply With Quote
Old 07-17-2009, 09:56 AM   #2
Try a Tang shank blade.
Here is the manual with the Makita blade numbers:
http://www.makita.com/en-us/Assets/I...nuals/4301.pdf
jerryh3 is offline   Reply With Quote
Old 07-17-2009, 08:01 PM   #3
Thanks!
Old 07-20-2009, 05:50 PM   #4
As it turned out, there was a small, broken piece of blade stuck in the saw. That's why neither the T nor U shank blades were fitting!
Old 07-20-2009, 09:53 PM   #5
Theres more then one way.
iMisspell's Avatar
Originally Posted by Pickngrin View Post
As it turned out, there was a small, broken piece of blade stuck in the saw....
Did you get it for a good deal ?
Maybe the old owner thought it was junk because of this and just wanted to get rid of it - jokes on them, if so.
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience -
- Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
Old 07-21-2009, 08:28 AM   #6
Well, another problem arose yesterday when I tested it out. The blade issue is resolved, but the saw intermittently does not switch on when I squeeze the trigger! I emailed the ebay seller last night...awaiting a response, but not holding my breath. In general, are such switches repairable or do they need to be replaced?
Old 09-01-2009, 08:09 AM   #7
You can look for DeWalt DW3720-5 3 Inch 14 TPI thick metal cutting jig saw blade bi-metal u-shank (5 Pack) Saw Blades with following features and specifications
  • Unique curved tooth design minimizes stress points for longer blade life and fast cuts
  • Cobalt steel (Bi-Metal) maximizes blade life and durability
  • U-Shank fits DeWalt and other universal shank jig saws
  • Cutting Length : 3 Inches
  • Teeth Per Inch: 14
biladam is offline   Reply With Quote
Sears 536.884351 auger blades are discontinued, no replacement MichaelLit General Discussion 2 07-08-2009 07:43 AM
Makita Sawzall blades? Speedball Tools 2 03-24-2009 06:13 PM
Makita bhp451 vs Makita bhp454 SeaOfRed75 Tools 1 03-04-2009 05:36 PM
Miter Saw Blades \ Crown Moulding Jigs Discussion WorkOnIt Carpentry 3 06-17-2007 05:50 AM
