-   Tools (http://www.diychatroom.com/f29/)
-   -   Makita 4301BV jig saw - what kind of blades do I need? (http://www.diychatroom.com/f29/makita-4301bv-jig-saw-what-kind-blades-do-i-need-49047/)
Pickngrin 07-17-2009 09:42 AM
I just bought a used Makita 4301BV jig saw on ebay. The new Bosch T-shank blades that I just bought at Lowes don't fit. To my (untrained) eye, it doesn't look like U-shank would, either (but don't have any to try). Does this model use special Makita blades, or.. ?
A Google search didn't help me on this one...
Thanks!
jerryh3 07-17-2009 09:56 AM
Try a Tang shank blade.
Here is the manual with the Makita blade numbers:
http://www.makita.com/en-us/Assets/I...nuals/4301.pdf
Pickngrin 07-17-2009 08:01 PM
Thanks!
Pickngrin 07-20-2009 05:50 PM
As it turned out, there was a small, broken piece of blade stuck in the saw. That's why neither the T nor U shank blades were fitting!
iMisspell 07-20-2009 09:53 PM
Originally Posted by Pickngrin (Post 304633)
As it turned out, there was a small, broken piece of blade stuck in the saw....
Did you get it for a good deal ?
Maybe the old owner thought it was junk because of this and just wanted to get rid of it - jokes on them, if so.
Pickngrin 07-21-2009 08:28 AM
Well, another problem arose yesterday when I tested it out. The blade issue is resolved, but the saw intermittently does not switch on when I squeeze the trigger! I emailed the ebay seller last night...awaiting a response, but not holding my breath. In general, are such switches repairable or do they need to be replaced?
biladam 09-01-2009 08:09 AM
You can look for DeWalt DW3720-5 3 Inch 14 TPI thick metal cutting jig saw blade bi-metal u-shank (5 Pack) Saw Blades with following features and specifications
  • Unique curved tooth design minimizes stress points for longer blade life and fast cuts
  • Cobalt steel (Bi-Metal) maximizes blade life and durability
  • U-Shank fits DeWalt and other universal shank jig saws
  • Cutting Length : 3 Inches
  • Teeth Per Inch: 14
