Originally Posted by End Grain
Thanks for the tips, PK. Much appreciated. BTW, is there any benefit at all in my using laminated layered wood (looks like plywood but stronger) for the sled's body over MDF? The local Rockler here in PHX occasionally has a few odd size pieces of it, but it is much more expensive than MDF.
Not sure what this "laminated layered wood" is that you're talking about. That's the definition of plywood. I'm guessing you're looking at a premium grade ply, like baltic birch, or ApplePly. Those are great for furniture, but they're not more stable than MDF. I'd use MDF for your sled, and hardwood for the front and back edge, and for the runners.
Remember to make the front and back tall enough that there will be lots of strength even after you've cut through them with the blade at full height. They should be about 5" tall for a 10" saw.
