Makeshift Scaffolding With Two Ladders - Tools - DIY Chatroom Home Improvement Forum
Old 06-11-2013, 12:11 AM   #1
Rewards Points: 1,062
Question
Makeshift scaffolding with two ladders
I have a really high stairwell to do walls around (cca 18 ft). Scaffolding is impractical. I had rigged a temporary platform that I used to hang drywall and it worked well but I had to remove it because it was anchored into the structural framing and I needed to hang drywall where it was anchored. So I was thinking to put a 20' ladder at the landing of the stairs or the first stair leaning onto the wall that faces the stairs. Then I want to take another, shorter ladder (one piece 10') and rest one side on or near the top of the stairs and the other somehow suspend on the big ladder to act as a bridge between the stairs and the big ladder. From there, most areas will be able to be reached for drywall taping and mudding and later on painting.
My question is, since both ladders are the same width, are there contraptions (hangers) to mount on the big ladder to which I can suspend the small horizontal one? I googled "ladder accessories" but didn't find anything like. What is an accessory like that called? Because I can't just insert the small one into the big one securely. I was thinking some secure buckle/hook should exist for this type of rigging precisely.
See illustration.
Old 06-11-2013, 12:48 AM   #2
jproffer's Avatar
Rewards Points: 706
Originally Posted by amakarevic View Post
How do I suspend the horizontal ladder?
You don't. Ladders aren't made to hold weight that direction. Some of them WILL, but that's not their strong direction.
Get a walkboard instead of the horizontal ladder and do as you show in the diagram. The walkboard may have a "hook" on each end you can hook over the ladder rung.
That still may not be recommended, but I would probably do it with a walkboard...NOT with a ladder though.
jproffer is offline   Reply With Quote
The Following 7 Users Say Thank You to jproffer For This Useful Post:
kwikfishron (06-11-2013), PaliBob (06-12-2013), r0ckstarr (06-11-2013), RWolff (06-11-2013), ToolSeeker (06-11-2013), Windows on Wash (06-11-2013), woodworkbykirk (06-11-2013)
Old 06-11-2013, 08:29 AM   #3
Rewards Points: 13,270
One of these works for me. Any box store or rental place will have one.
http://us.wernerco.com/view/Products...ks/PA200/PA208
I've also used a section of LVL or glue lam in a pinch.
Gymschu (06-22-2013)
Old 06-11-2013, 09:08 AM   #4
jproffer's Avatar
Rewards Points: 706
Absolutely. I would do it with something I built (small 'floor' section-ish thing). It wouldn't have to be a manufactured walkboard...but definitely not a ladder.
Old 06-11-2013, 09:26 AM   #5
I also would never lean that ladder againt the wall like that. The rungs can go right through the sheetrock.
I use one like this instead.
http://www.gorillaladders.co.nz/webf...ructionsV1.pdf
I bought mine at Wal-Mart for about $100.00.
Old 06-14-2013, 02:17 PM   #6
Rewards Points: 280
I often build a "plank" from 2X4 and plywood. Can be built to any size. 2 long 2x4 and several short cross pieces, usually about 12" wide. I always screw them together and disassemble when done.
HTH JIm
jjrbus is offline   Reply With Quote
The Following User Says Thank You to jjrbus For This Useful Post:
Old 06-14-2013, 02:53 PM   #7
jproffer's Avatar
Rewards Points: 706
HTH JIm
You had me until you said you screwed 'em together.
But that's a whole different argument...anyone got Mike Holmes' number so he can give his 2 cents?
Old 06-14-2013, 05:01 PM   #8
Rewards Points: 280
No screwing?
Old 06-14-2013, 08:09 PM   #9
jproffer's Avatar
Rewards Points: 706
Contrary to what's shown on MH's favorite show...screws don't have the shear strength that nails have.
EDIT TO ADD: You can screw the plywood onto the framing so you can remove/reuse it...but I would nail the frame.
The Following User Says Thank You to jproffer For This Useful Post:
woodworkbykirk (06-14-2013)
Old 06-14-2013, 08:33 PM   #10
Rewards Points: 280
Too vague a statement, but then I should have been more specific. If you are referring to what is commonly called "drywall screws" I would have to agree.
I am big on screwing! JIm
Old 06-14-2013, 08:41 PM   #11
kwikfishron's Avatar
Rewards Points: 176
Buy a 2x12 (or two) and you'll be fine. Don't cut them, get them dirty (mud/paint) or poke holes in them and you can return them. I've done that same stairwell setup many times that way (I keep the 2x12's though).
kwikfishron is online now   Reply With Quote
Old 06-15-2013, 02:40 PM   #12
jproffer's Avatar
Rewards Points: 706
No screw (except maybe lag screws) have the strength of a nail. In the pull-out direction, yes...in the shear direction, no.
And I'm big on screwing too , but I use nails, mostly.
Old 06-16-2013, 09:50 PM   #13
Rewards Points: 280
There really is no shear strength involved. The long 2X4 are continuous with the 2X4 spacers, being just that, spacers, screwed in. The plywood is screwed to the tops of the 2X4's.
I love my cordless drill and screw everything. JIm
Old 06-16-2013, 11:02 PM   #14
jproffer's Avatar
Rewards Points: 706
Ok
When you're standing in the middle of it, and your feet don't happen to be over either of the long 2x4s, and the screws shear off and drop you, you'll see more clearly what I mean.
To each their own though
Old 06-17-2013, 09:35 AM   #15
Rewards Points: 280
One of us is missing something? In the unlikely event that all the screws sheared off, it would not drop. There is no shear involved?
I prefer and feel safer on this than a single 2X12 plank, that is a personal opinion.
JIm
Tags
ladder , safety , scaffolding
Extension ladder length question Ed G General DIY Discussions 21 10-05-2011 10:17 AM
are all fiberglass ladders insulated? SubSailor Electrical 9 11-11-2010 12:35 PM
Is this a bad idea??? drillbit Building & Construction 3 08-19-2008 10:14 AM
scaffolding rizaydog General DIY Discussions 8 02-10-2008 09:47 PM
little giant ladders????? lucyann Tools 4 11-05-2007 03:17 PM
