Lube For 40 Yr Old Scroller Saw?? - Tools - DIY Chatroom Home Improvement Forum
Old 02-14-2011, 11:11 AM   #1
Lube for 40 yr old scroller saw??
I own a Craftsman 1" scroller saw from 1969. I use it about twice a year. I opened the a front plate, and the cavity with the gears in it contains lots of very heavy lubrication, or grease. It's very thick and dark amber. The operating instructions say that the saw is permanently lubricated for the normal operating life of the saw, but I'm wondering if the grease needs replacing after 40 years. When I use it now, it takes about 30 seconds to get up to speed (probably while the grease heats up and thins out).
After I clean out the old grease, what should I use for replacement? Or should I just leave the old grease in there? What do you suggest?
Thanks,
Jim G
jimgrout is offline   Reply With Quote
Old 02-14-2011, 11:58 AM   #2
DIY staff
Rewards Points: 7,174
I usually use lithium grease----I don't know what would be the right viscosity for those gears,however.
Old 02-14-2011, 12:39 PM   #3
Rewards Points: 79
Almost sounds like automotive bearing grease. I would imagine that would be OK to use as a replacement.
itguy08 is offline   Reply With Quote
The Following User Says Thank You to itguy08 For This Useful Post:
oh'mike (02-14-2011)
Running A New 220 Service Underground toddthor Electrical 14 01-21-2011 04:39 AM
lube for food slicer TIMOTHY 1224 Appliances 3 07-11-2010 08:55 PM
DeWalt planer - what kind of lube Richo Tools 4 01-28-2010 02:18 PM
No Pull lube jamiedolan Electrical 7 12-16-2008 01:00 PM
