Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 12-26-2012, 03:09 PM   #1
Looking for a small Band Saw
Hi,
One of the victims of Hurricane Sandy was my Delta Mini-Band Saw. (I've heard a lot differing opinions on this saw, but it's currently discontinued and it suited my needs just fine.)
I mostly used this to cut fishing plugs. (I turn the plugs on a mini-lathe, then use the band saw for straight clean cuts - Or I used flat boards and used the band saw to cut out the shape in advance of cleaning them up...)
Anyway - it was underwater and a complete loss. So I'm looking for a new one.
The problem I'm finding is that every single review of these "Mini" saws seems to by negative. I think part of the problem is that people expect too much. People buy these things expecting to become Norm from This Old-Yankee... When in reality they are not really even meant for "weekend warriors". I'm looking for something that is going to be cutting out fishing plugs, or maybe the occasional pine-wood-derby racer...
Does anyone have any suggestions? My problem is that I can't determine which reviews are actually reviews of BAD products - and which are people with unrealistic expectations of a 9" or 12" Band saw....
Cost is important, but size is more important. I usually kept this thing on the ground - under a table (Why Sandy got it...) - I do not have room in my shop for a full "Stand Up" saw.
mpwalsh is offline   Reply With Quote
Old 12-26-2012, 04:57 PM   #2
As simple scroll saw would do what little your asking.
The trouble with small bandsaws is the small drive wheels that have such a small radius it can cause the welds to crack and fail in the blades.
Still want a small band saw then look into the 14" or 12" Jet, or Grizzley.
Old 12-26-2012, 06:06 PM   #3
If you could find a small 9" similar to this older Delta Home Craft you'd be set for life or until the next storm at least. I haven't needed any parts but I believe they are available. It's light enough to be moved around if need be.
Fairview is offline   Reply With Quote
Old 12-26-2012, 06:08 PM   #4
Suggestions on a brand?
I'm not hung up on the Band Saw idea, it's just what I grew up on and previously had owned. If a Jig Saw would do the job - please recommend one.
Also - you mean a stationary - "Shop" jigsaw... Right? Not a "Saber Saw" or Hand-held model.... Right?
Old 12-26-2012, 10:43 PM   #5
i have a 10y/o model of this one. it works very well, with a new bimetal blade. though getting the blade to stay on was a little trial and error.
http://www.harborfreight.com/horizon...saw-93762.html
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 12-28-2012, 10:09 AM   #6
Almost all the manufactures that make band saws also make a bench top model from roybi to the big boys.
Old 12-31-2012, 07:51 PM   #7
In a little over my head
I don't own one, but have heard very good things about the benchtop and 12" Rikons. It seems like I've seen the benchtops for sale for around $200.
ratherbefishing is offline   Reply With Quote
Small dip in concrete floor. kath81 Flooring 3 11-12-2010 05:32 PM
heating small bathroom floor - maybe rtoni Flooring 0 09-22-2010 04:11 PM
Small holes forming in newly poured concrete chitownIrish Building & Construction 4 07-10-2010 03:24 PM
Small room hardwwod refinish deejclow Flooring 1 04-29-2010 07:16 AM
Curved Small Stage jalaux Carpentry 1 07-09-2006 10:57 PM
