-   Tools (http://www.diychatroom.com/f29/)
-   -   Looking for a small Band Saw (http://www.diychatroom.com/f29/looking-small-band-saw-167421/)
mpwalsh 12-26-2012 02:09 PM
Hi,
One of the victims of Hurricane Sandy was my Delta Mini-Band Saw. (I've heard a lot differing opinions on this saw, but it's currently discontinued and it suited my needs just fine.)
I mostly used this to cut fishing plugs. (I turn the plugs on a mini-lathe, then use the band saw for straight clean cuts - Or I used flat boards and used the band saw to cut out the shape in advance of cleaning them up...)
Anyway - it was underwater and a complete loss. So I'm looking for a new one.
The problem I'm finding is that every single review of these "Mini" saws seems to by negative. I think part of the problem is that people expect too much. People buy these things expecting to become Norm from This Old-Yankee... When in reality they are not really even meant for "weekend warriors". I'm looking for something that is going to be cutting out fishing plugs, or maybe the occasional pine-wood-derby racer...
Does anyone have any suggestions? My problem is that I can't determine which reviews are actually reviews of BAD products - and which are people with unrealistic expectations of a 9" or 12" Band saw....
Cost is important, but size is more important. I usually kept this thing on the ground - under a table (Why Sandy got it...) - I do not have room in my shop for a full "Stand Up" saw.
joecaption 12-26-2012 03:57 PM
As simple scroll saw would do what little your asking.
The trouble with small bandsaws is the small drive wheels that have such a small radius it can cause the welds to crack and fail in the blades.
Still want a small band saw then look into the 14" or 12" Jet, or Grizzley.
SeniorSitizen 12-26-2012 05:06 PM
1 Attachment(s)
If you could find a small 9" similar to this older Delta Home Craft you'd be set for life or until the next storm at least. I haven't needed any parts but I believe they are available. It's light enough to be moved around if need be.
mpwalsh 12-26-2012 05:08 PM
Suggestions on a brand?
I'm not hung up on the Band Saw idea, it's just what I grew up on and previously had owned. If a Jig Saw would do the job - please recommend one.
Also - you mean a stationary - "Shop" jigsaw... Right? Not a "Saber Saw" or Hand-held model.... Right?
Fix'n it 12-26-2012 09:43 PM
i have a 10y/o model of this one. it works very well, with a new bimetal blade. though getting the blade to stay on was a little trial and error.
http://www.harborfreight.com/horizon...saw-93762.html
ToolSeeker 12-28-2012 09:09 AM
Almost all the manufactures that make band saws also make a bench top model from roybi to the big boys.
ratherbefishing 12-31-2012 06:51 PM
I don't own one, but have heard very good things about the benchtop and 12" Rikons. It seems like I've seen the benchtops for sale for around $200.
