Looking For A Plasma Cutter - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-09-2014, 03:32 PM   #16
Rewards Points: 6,652
Yes if it is a large scaled operation. What the OP is wanting to do. Those kind of setups use a bottle of Inert gas. The system that a commercial operation uses to make the compressed gas so that it will work properly with a commercial Plasma Cutter. They would never be able to purchase or have the space required for it.
If the OP is talking about 3 phase. They would be using it inside a commercial space or overseas. Again, you are talking $$$. Especially since they are talking about playing around with 2" stock. You just do not lift stock that size up by hand.
Old 04-09-2014, 03:38 PM   #17
Rewards Points: 392
Clean, dry compressed air is typically use for plasma cutting, why would you need an inert gas for cutting?
rustyjames is offline   Reply With Quote
Old 04-09-2014, 04:03 PM   #18
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,358
Originally Posted by Anti-wingnut View Post
I worked in heavy steel fabrication for 20 years. Some processes like gouging special stainless steel pipe will use inert gas to increase the heat and minimize the amount of carburized material. But 99.9% of plasma cutting is with compressed air. Could you be mistaking air filters and desiccants for something else? Could you be viewing machines in a particular industry? Could you be mistaking a MIG or TIG machine for a plasma cutter? Or could you be wrong?
Ayuh,.... Wrong, or confused, I'd say,...
For 2" plate, I'd break out the Oxy/ Ac torches, 'n change out to a Big tip,....
As noted, 2" is some Big stuff, much more than a square foot, 'n yer not gonna throw it 'round, by hand,...
Bondo is online now   Reply With Quote
Old 04-09-2014, 04:18 PM   #19
Oso954's Avatar
Rewards Points: 1,110
Ferrous metals compressed air is fine.
Any non-ferrous metal or low ferrous alloys, inert gas.
Oso954 is online now   Reply With Quote
Old 04-09-2014, 06:08 PM   #20
Rewards Points: 1,010
I'm afraid you have no idea of what your talking about.
Anti-wingnut is offline   Reply With Quote
Old 04-09-2014, 06:26 PM   #21
While different gasses can be used for plasma cutting, most people today use compressed air for the plasma gas. In most shops, compressed air is readily available, and thus plasma does not require fuel gas and compressed oxygen for operation.
http://www.lincolnelectric.com/en-us...cs-detail.aspx
Old 04-09-2014, 10:16 PM   #22
Rewards Points: 392
So you're saying you can't cut aluminum with air?
Old 04-09-2014, 10:57 PM   #23
Gasses give a better edge than air cuts, but either will cut.
http://www.thefabricator.com/article...tting-aluminum
Old 07-27-2014, 04:52 AM   #24
Rewards Points: 850
i found mine at a estate sale. didnt know powermax until i got it home. its a powermax 350. think it sold new for around $800.00 or $900.00. looks brand new and came with some consumables. now i did have to give the guy $72.00 for it. i asked him if it was a plasma cutter and he said id know more about it then him. he said it should be worth $75.00 and i reached into my wallet, only had $72.00 on me, he said = you can get more, i started to leave and he said ok give me the $72.00. had no idea that powermax was a leading maker. and no i wont sell it for $75.00.
hotrod351 is offline   Reply With Quote
Old 07-27-2014, 07:35 PM   #25
Household Handyman
Rewards Points: 1,408
The Longevity unit advertises that it will cut "up to 2" thick steel at 100 amps 220 volts/3 phase with a 60% duty cycle and uses compressed air supplied at 45--65 psi. I have a whole bunch of experience with plasma torches, mig welders, stick, tig, etc. and on and on. Using this Longevity machine to cut 2" thick steel is going to do two things for sure: 1) suck up a whole bunch of electricity, even with 220 v @ 3 ph., 2) stating that it will need 45-64 psi of compressed air is one thing but the specs DO NOT state at what CFM the air must be supplied to this plasma unit. I have a 1 HP air compressor that I know can supply 45-65 psi of compressed air each time you press the trigger of a blow off gun, but not for long. As you use the air you would need a compressor that could keep giving you this 45-65 psi at a constant flow rate for as long as you have the plasma torch operating. And for a plasma torch you will need clean dry air. This is not something you get from your everyday shop compressor. I have a plasma cutter in my home shop and there is a dual filter/dryer set-up on it. Then you have to go back to the 60% duty cycle. How long, in distance, do you plan on cutting this 2" steel? With a 60% duty cycle you can cut a maximum of 6 minutes out of a ten (10) minute period then have to let the machine cool down for 4 minutes. And the cost of this unit--I won't disclose that here, but please do your homework before spending that much money on a unit to make sure it is what you need- - -and not just want.
Old 07-27-2014, 08:09 PM   #26
Why would anyone want to spend the big bucks on a machine to cut thick plate when an oxy/acetylene torch would do the same job at a small fraction of the price?
This makes no sense...
My line burner can cut thick plate so smooth you'd almost think it was sheared off...
PaulBob is offline   Reply With Quote
The Following User Says Thank You to PaulBob For This Useful Post:
davido30093 (07-29-2014)
Old 12-09-2015, 12:52 AM   #27
Rewards Points: 2
If you are looking at an easy-to-use plasma cutter, here is a good option: Lotos LT5000D - Good for easy project
soloism is offline   Reply With Quote
