Looking For A Laser Level Tool - Tools - DIY Chatroom Home Improvement Forum
Old 04-22-2010, 07:25 AM   #1
Looking for a laser level tool
I am looking for a laser level, to align my photo and pictures on wall.
DIYFREEMAN is offline   Reply With Quote
The Following User Says Thank You to DIYFREEMAN For This Useful Post:
Boston Bean (09-22-2010)
Old 04-22-2010, 07:49 AM   #2
Military Mom of 4
Snav's Avatar
I have never dealt iwth a laser level - so I have no advice in that area.
However, I was a framer for years and my advice is to measure and relocate hangers or shorten wires to get the hanging point of all your pictures at the same spot - that will help.
Of course using any other tool to help mark and measure distance/etc will help, too - but if your wires and brackets are all different it makes it more complicated.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 04-22-2010, 08:00 AM   #3
GREAT. Thanks for advice, I will try your method once I back home.
But I am also interesting on laser, cause I have seen a guy using laser level before.
It looks great but the price is relative high (up to 1000USD).
I am checking the video one, if below my budget (250USD) I may try it!!
Old 04-22-2010, 10:23 PM   #4
jschaben
Rewards Points: 502
Hi - Ive got a Black and Decker Crossfire that I like a lot. Use it for a lot a lot more than hanging pictures also.
I did some research on the one in the video. I could only find them sold in wholesale quantities, minimum order of 100 units. Price was $90-100/USD ea FOB Hong Kong. Can imaging the price when they hit the beach here.
The Crossfire self levels and shoots a vertical, horizontal or both beams. Beam is visible for 20 or so feet in a normally lit indoor room. Pretty much usless outside on a bright day though. I got mine through Amazon:
http://www.amazon.com/Black-Decker-B...1991894&sr=1-1
jschaben is offline   Reply With Quote
Old 04-23-2010, 05:59 AM   #5
It is funny, do it needs to use with tripod? I don't want to carry a tripod at different location.
Thanks for your recommendation!!
Old 04-25-2010, 08:44 AM   #6
Household Handyman
Rewards Points: 1,408
I have a laser level which I'm sure was under the $50 range. It shoots a horizontal line, a vertical line, and a cross-type line. It can be tripod mounted, I use my camera tripod, and I have just sat it on something stacked up to be the right height. It's in my work trailer, can't remember the name but it's yellow-bought at the orange apron store. For picture hanging I use a wooden yard stick with a screw through it at six (6) inches. I hang the picture on the screw head, hold the yardstick up and have someone (customer, friend) view the picture at the correct height and level with other pictures. Then-I slightly press the screw point to mark exactly where I should put my mounting anchor. This has always worked good for me. David
Old 04-25-2010, 12:09 PM   #7
jschaben
Rewards Points: 502
Smile
The Black and Decker doesn't need a tripod, just sit it on any convenient flat surface; ladder rung, mantlepiece, window sill. Or, you can hang it from the the ceiling or other overhang. It has a tie point on top. Or, you can hang it on a wall, has a keyhole hanger slot on the back. There is a tripod mounting hole but is a bit difficult to mount on a camera tripod. The screws on the tripods tend to be a bit short.
Old 04-25-2010, 12:21 PM   #8
Laser levels come in many price ranges and qualities. I saw one that was reasonably priced, but after reading the package, found it was "accurate to within 3/8" in 30 feet". To me, that is not accurate. Remember that your pictures are hanging on a wall, and the ceiling (which is what people will also see) may not be level. Take a measurement down from the ceiling in a couple places and throw up a normal level across the marks to see if it is within your standards.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 04-26-2010, 06:56 AM   #9
Hi all, I just got a laser level finally!! I search a lot in website, and got a manual laser level device. It is in my budget, below 100.
It is only palm size with angle finder and laser line, and it is rechargeable!! I hate to purchase one time only battery. That's great for me.
I like the laser line, I can put it close to wall and draw the line in any angle immediately.
I am planning to mount my pictures in a ladder shape, with laser line aligned in 45 degree.
Old 04-26-2010, 09:18 AM   #10
jschaben
Rewards Points: 502
Great, which one did you get...?
Old 04-26-2010, 09:23 AM   #11
I got that one which called SlopeView TLL90.
http://www.viddler.com/explore/LindaYu/videos/4/
Old 04-26-2010, 09:26 AM   #12
The specification can be found in this web:
http://www.mib-instruments.com/servl...tractor/Detail
Old 04-26-2010, 10:01 AM   #13
jschaben
Rewards Points: 502
Thumbs up
Looks like a nice score. Only thing I noticed on the specs is apparently it only has a magnetic base for mounting. Also noticed in the last video that the guy never turned loose of it working on the wall. May need to get a bit creative there. Other than that looks like a great deal for the money. Keep us posted on how you like it
Old 04-26-2010, 10:22 AM   #14
That laser is little bit different that I knew.
It seems that special for drawing laser line on wall.
It don't need to place in a distance from the wall, but just put the device on the wall to draw the line.
The is a link from the same guy show how to draw on wall, I will take a video myself at later time:
http://www.viddler.com/explore/LindaYu/videos/3/
Old 04-26-2010, 10:32 AM   #15
jschaben
Rewards Points: 502
Yeah, that's the video I was talking about. Notice he never takes his hand off the instrument. Looks like you will need to hold the instrument with one hand and draw a line with the other unless I'm missing something.
John Schaben
"Where all think alike, no one is thinking very much"
Tags
laser level
how do i use a rotary laser level? eric131 Building & Construction 7 05-18-2009 11:29 PM
rotary laser level eric131 Carpentry 1 05-18-2009 10:10 PM
Laser Level - Eyewear Required? mfleming Safety 19 01-05-2009 10:09 PM
Laser level bubble dried up. ramakristan Tools 3 10-13-2007 07:38 AM
Shopping for a laser level - opinions appreciated. Kevin K Tools 8 05-08-2007 05:43 PM
