Left Blade Circular Saws - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-09-2012, 09:38 PM   #16
Rewards Points: 81
Originally Posted by framer52 View Post
all of the cordless saws are left handed.
I have the PC lefty
I have a 18v cordless black and decker that has the blade on the right.
Is your PC corded?
Here's the 2 I've been looking at...
Bosch- http://www.amazon.com/Bosch-CS5-120-.../dp/B000WMDBIE
Milwaukee- http://www.amazon.com/gp/product/B00...4V42JG2W78RGDR
Total Tool is offline   Reply With Quote
Old 02-09-2012, 10:16 PM   #17
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
it doesnt matter which way the design on the blade is facing... the only thing you need to pay attention to is the direction of the teeth.. they cut on the up through the bottom of the material...
woodworkbykirk is offline   Reply With Quote
Old 02-09-2012, 11:14 PM   #18
Rewards Points: 506
Actually, the leading edge of the cut travels downward through the material (from top to bottom). This is a result of a round blade moving forward, and also because the foot can never be higher than the CL of the blade. This is evidenced by the bottom of the material being the 'last' area to be cut. The teeth are moving up, but the cut is moving from top to bottom.
jlmran is offline   Reply With Quote
The Following User Says Thank You to jlmran For This Useful Post:
Total Tool (02-09-2012)
Old 02-09-2012, 11:38 PM   #19
Rewards Points: 81
This thread seems to be fatally derailed.
It's just about saws with the blades on the left. Not about blades or which side the blades labels are on.
Old 02-10-2012, 07:03 AM   #20
Rewards Points: 506
OK...to answer your original question: The Skilsaw wormdrive Made in USA. To get one will require shopping the "used" market, I believe.
Old 02-10-2012, 07:27 AM   #21
the Musigician
DangerMouse's Avatar
My DeWalt DC390 cordless has served me very well for years.
DM
Old 02-10-2012, 04:07 PM   #22
the only way for a circ saw to cut on the downstroke is if you are going backwards..... as the blade cuts up from below at the front of the saw.. believe it or not this is a question that is asked on the national exam for a carpenters red seal
Old 02-10-2012, 04:37 PM   #23
Rewards Points: 506
I didn't say "on the downstroke". I said the cut moves downward.
True or false: at any given point along the cut line, the bottom of the material is the last portion to be cut?
True. The stock is being cut from top to bottom.
I would be inclined to challenge the authors of the national carpenters red seal exam.
Old 02-10-2012, 04:48 PM   #24
A Little Of Everything
Rewards Points: 1,364
DM
That's the exact same saw I've got. I absolutely love the thing.
DrHicks is offline   Reply With Quote
Old 02-10-2012, 06:48 PM   #25
then why is it that when your making finish grade cut on a peice of wood you put the good side down when using a circular saw.
Old 02-10-2012, 07:03 PM   #26
KemoSabe
loneframer's Avatar
The blades tooth still makes the cut from the bottom of the material upwards.
The fact that the blade is circular has no bearing upon whether it cuts on the upstroke or not. The fact that it rotates from bottom to top does.
If you want to get technical, the cut does not move from top to bottom or vice-versa, it moves forward from the beginning of the cut to the end.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 02-10-2012, 07:09 PM   #27
Rewards Points: 506
Because the teeth are moving upward...as you and I both originally stated. This moves the splinters into the stock, if you will. It's just that the top surface of the stock gets cut before the bottom surface, so the entire cut along the stock moves from top to bottom.
Old 02-10-2012, 07:15 PM   #28
Rewards Points: 506
Ehhh, not really.
1. Any given tooth will contact the highest level of available stock in its path.
2. The circular shape has EVERYTHING to do with this phenomenon. Remember, the foot on a normal saw can't be higher than the center of the blade.
3. The cut only moves forward if you push the saw forward. I'm discussing the vertical components...which in fact are derived when one pushes (or pulls) the saw.
Old 02-10-2012, 07:18 PM   #29
Rewards Points: 506
Draw a vertical line on the end of a board. Then look at it and imagine a circular saw cutting through the board.
How does the line get cut? Top down or bottom up?
Old 02-11-2012, 04:13 AM   #30
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I'm with jimran on this. If you take away the saw in the middle of a cut it is clear that the bottom side of the material is the last to be cut.
Disclaimer
& Stay Safe
.....Bob Lavery
Did I put circular saw blade on correctly? joetab24 General DIY Discussions 5 11-10-2010 02:54 PM
center flange on masonry blade tearing hughnohoo Tools 3 11-07-2010 07:39 PM
cutting plywood panels w circular saw Klawman Carpentry 11 12-11-2009 02:40 PM
Using circular saw blade in a chop saw rayem723 Carpentry 5 10-27-2008 09:08 PM
when buying circular saw from Ebay be aware to ask KUIPORNG Tools 4 05-04-2007 10:29 AM
