Left Blade Circular Saws - Tools - DIY Chatroom Home Improvement Forum
Old 02-08-2012, 10:56 PM   #1
Rewards Points: 81
Left blade circular saws
Who makes a quality left blade circular saw? I know Bosch and Milwaukee each make one. I think porter cable does too. Other than that, I dont really know of anything.
Anyone have any recommendations? Why dont more companies offer saws with blades on the left side of the motor?
Total Tool is offline   Reply With Quote
Old 02-08-2012, 11:00 PM   #2
DO IT RIGHT THE 1st TIME!
Because most people who want a Left blade style go with a Wormdrive i would think. Milwaukee makes a great one (left blade circular) in my opinion. As for worm drives, I like the one bosch has to be honest.
builttolast is offline   Reply With Quote
Old 02-09-2012, 01:55 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by Total Tool View Post
Why dont more companies offer left blades?
All blades are unisex. They can be used on RH or LH circular saws.
Disclaimer
& Stay Safe
.....Bob Lavery
The Following 2 Users Say Thank You to PaliBob For This Useful Post:
Nailbags (02-11-2012), woodworkbykirk (02-09-2012)
Old 02-09-2012, 03:42 AM   #4
But the ones that are marketed for LH saws have blade direction, manufacturer name etc showing while on saw! Blades marketed for RH saws will have info on blade not visible ie facing in when put on saw! For example a Freud 6 -1/2 inch blade bought for my Milwaukee LH 6310 18 volt saw has info showing but the CMT blade bought for the same saw has info facing in! So Freud had cordless LH saws in mind designing blade. It's just a pain to check that blade direction arrows match when info is on inside!
toolaholic is offline   Reply With Quote
Old 02-09-2012, 04:17 AM   #5
Tool Geek
PaliBob's Avatar
Originally Posted by toolaholic View Post
It's just a pain to check that blade direction arrows match !
After you've changed a few, it's easier to remember.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-09-2012, 06:24 AM   #6
Rewards Points: 13,450
Since about 99% of ciruler saws are right hand why would any company invest the money to do that?
Not only would they have to lable everyone of the differant blades they make but then who's going to buy them? No distributor or sales outlet is going to give them the shelve space for an item with that low a turn over rate.
Old 02-09-2012, 07:09 AM   #7
Rewards Points: 81
I'm not sure how anyone would think I was talking about just the blades...
The title of the thread is left blade circular saw. Anyone have input on those? Or know of any besides the Milwaukee or bosch?
Old 02-09-2012, 07:11 AM   #8
Guess it's not that expensive to stamp, print etc info on the other side! FWIW I use my Bosch 1578 LH blade top handle the most! My old Dewalt 357 Right hand blade sidewinder doesn't come out to play much!
Old 02-09-2012, 07:14 AM   #9
I like the blade on the left! Cause as right handed person I can watch the blade cut through the line w/o looking over the saw! Plus I like the extra torque of a worm drive which are left hand blades!
Old 02-09-2012, 07:14 AM   #10
Your right, my mistake. I think it's the last line in your post that started that line of thought. Once you go back and read your post agin it makes more since.
Old 02-09-2012, 07:16 AM   #11
Anyone have any recommendations? Why dont more companies offer left blades?
I like my bosch 1578! Not made anymore but can still be found! I like the top handle.
Most workers are rear handle!
Old 02-09-2012, 07:18 AM   #12
Sorry it's the 1678!
Old 02-09-2012, 08:25 AM   #13
raylo32's Avatar
Rewards Points: 1,254
Makita makes an 18V cordless left blader, the BSS610Z.
raylo32 is offline   Reply With Quote
Old 02-09-2012, 08:32 AM   #14
Rewards Points: 528
all of the cordless saws are left handed.
I have the PC lefty
framer52 is offline   Reply With Quote
The Following User Says Thank You to framer52 For This Useful Post:
Old 02-09-2012, 01:29 PM   #15
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
I also find it odd that most saws have the blade on the right. If you are right handed, it would make more sense if the blade was on the left where you can see it better while cutting. When I was in the market for one I could not find any so I settled for one with the blade on the right. You can still kinda peak at it, but it requires getting your face a little closer. Wear those safety goggles. It also depends if you are cutting away from yourself, or sideways. If you are cutting sideways then it's not so much an issue. Depends what you are cutting and how you're placed.
Oddly,. the cordless ones seem to have the blade to the left, not sure why only the cordless ones though. My guess is the AC motors probably all come from the same manufacturer and they are designed to spin a certain way.
Did I put circular saw blade on correctly? joetab24 General DIY Discussions 5 11-10-2010 01:54 PM
center flange on masonry blade tearing hughnohoo Tools 3 11-07-2010 06:39 PM
cutting plywood panels w circular saw Klawman Carpentry 11 12-11-2009 01:40 PM
Using circular saw blade in a chop saw rayem723 Carpentry 5 10-27-2008 08:08 PM
when buying circular saw from Ebay be aware to ask KUIPORNG Tools 4 05-04-2007 09:29 AM
