Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 10-29-2012, 08:15 PM   #1
Last Four Nails in Porter Cable F350A
I'm a newcomer to framing nailers and have been reading the Porter Cable F350A manual. Apparently the F350A locks out and won't fire when the number of nails remaining is down to four. The manual says you need to remove these nails before reloading it or they will cause a jam. The question is this: must these four nails be wasted? Or, because it is possible to load two clips of nails, one behind the other, can I just stop sooner when there are, say, 10 nails left, then loan another clip behind? Thanks in advance for any advice.
peterajansson is offline   Reply With Quote
Old 10-29-2012, 08:33 PM   #2
Super Moderator
Will jamb? I doubt it---may? Sometimes----
On rare occasions the last nail in the clip will drop and jamb---but I never throw away the last nails--but I try hard not to shoot the last nail---my gun doesn't have the 'out of bullets' feature----
When you start to run out of nails---add more---and don't be concerned----jamb are rare in that gun---and easy enough to clear if they do happen---
Old 10-29-2012, 11:39 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
this is common with nailers.. when they get down to the last few nails the rack already in the gun tends to slip and no longer sits at the correct angle in the magazine... a good gun wont get affected.. ok guns will misfire once or double fire .. ****ty guns jamb and do it constantly.. the new line of porter cable guns arent exactly a pro grade tool where as the old stuff was
woodworkbykirk is offline   Reply With Quote
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
AtlanticWBConst. (10-30-2012), ToolSeeker (10-30-2012)
Old 10-30-2012, 07:50 AM   #4
Super Moderator
New is not as good as the older one---I had not thought of that----
Old 10-30-2012, 08:37 AM   #5
A "Handy Husband"
rjniles's Avatar
Remove the nails, reload, put tbe 4 nails back in. That way it is always the same 4 nails.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 10-30-2012, 09:09 AM   #6
Good one. Somebody's always got the better idea.
Ed911 is offline   Reply With Quote
Old 10-30-2012, 12:06 PM   #7
AHH, SPANS!!!
I've used air guns that did not shoot the last remaining few nails in the clip, just load a new rack in on top of the 4 remaining and keep on shooting. after a while you get as feel for when it needs reloading and you do it before the clip reaches the last few nails in the rack. a senco trim gun I used would not allow a full rack to be inserted while the last few rack nails that would not shoot are stuck in the clip so I always cut the new nail rack in half and used them that way..
hand drive is offline   Reply With Quote
Old 11-02-2012, 02:19 PM   #8
Thanks all. Good informatin, all that I will need. I very much appreciate your help.
Armored cable shell as conduit? sixspeed Electrical 13 10-18-2012 04:45 PM
Me ranting about nails... Pittsville Building & Construction 14 10-05-2012 01:26 PM
Is Tray Cable acceptable for Residential use? MisterSteve Electrical 43 02-21-2012 01:35 AM
Coaxial Cable Junction Box/Split apriest Electrical 19 07-23-2009 09:33 PM
Framing Nailer (Porter Cable) Renovator Tools 2 04-26-2006 07:43 PM
