-   Tools (http://www.diychatroom.com/f29/)
-   -   Last Four Nails in Porter Cable F350A (http://www.diychatroom.com/f29/last-four-nails-porter-cable-f350a-161562/)
peterajansson 10-29-2012 07:15 PM
I'm a newcomer to framing nailers and have been reading the Porter Cable F350A manual. Apparently the F350A locks out and won't fire when the number of nails remaining is down to four. The manual says you need to remove these nails before reloading it or they will cause a jam. The question is this: must these four nails be wasted? Or, because it is possible to load two clips of nails, one behind the other, can I just stop sooner when there are, say, 10 nails left, then loan another clip behind? Thanks in advance for any advice.
oh'mike 10-29-2012 07:33 PM
Will jamb? I doubt it---may? Sometimes----
On rare occasions the last nail in the clip will drop and jamb---but I never throw away the last nails--but I try hard not to shoot the last nail---my gun doesn't have the 'out of bullets' feature----
When you start to run out of nails---add more---and don't be concerned----jamb are rare in that gun---and easy enough to clear if they do happen---
woodworkbykirk 10-29-2012 10:39 PM
this is common with nailers.. when they get down to the last few nails the rack already in the gun tends to slip and no longer sits at the correct angle in the magazine... a good gun wont get affected.. ok guns will misfire once or double fire .. ****ty guns jamb and do it constantly.. the new line of porter cable guns arent exactly a pro grade tool where as the old stuff was
oh'mike 10-30-2012 06:50 AM
New is not as good as the older one---I had not thought of that----
rjniles 10-30-2012 07:37 AM
Remove the nails, reload, put tbe 4 nails back in. That way it is always the same 4 nails.
Ed911 10-30-2012 08:09 AM
Good one. Somebody's always got the better idea. :thumbsup:
hand drive 10-30-2012 11:06 AM
I've used air guns that did not shoot the last remaining few nails in the clip, just load a new rack in on top of the 4 remaining and keep on shooting. after a while you get as feel for when it needs reloading and you do it before the clip reaches the last few nails in the rack. a senco trim gun I used would not allow a full rack to be inserted while the last few rack nails that would not shoot are stuck in the clip so I always cut the new nail rack in half and used them that way..
peterajansson 11-02-2012 01:19 PM
Thanks all. Good informatin, all that I will need. I very much appreciate your help.
