Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 08-11-2012, 06:18 AM   #1
Laser distance meters, recommendations please
Best distance meter under $200 ?
Thanks.
Spud is offline   Reply With Quote
Old 08-11-2012, 03:13 PM   #2
sdsester's Avatar
What kind of distances are you measuring and to what degree of accuracy? Indoors or outdoors? Sure a laser is what you want?
sdsester is online now   Reply With Quote
Old 08-12-2012, 01:35 AM   #3
Indoors and outdoors.
Length , 3 fullsize crew cab pickups.
Accuracy, trying for 1mm.
Old 08-12-2012, 08:09 AM   #4
sdsester's Avatar
I have a Northwest somewhat like the one shown for about $150 that is supposedly accurate to 1.5mm. See if any at the URL will work for you? Needing one to work outside is the tricky part; make sure you get one bright enough as the glasses only help so much. Look for one that will calculate triangles to give you the length of one side. Just another way of tweaking accuracy to what you need. I haven't shopped for one in awhile and am pleased to see prices have actually dropped some.
http://www.engineersupply.com/laser-measurers.aspx
I used my digital measuring things mainly to get square footage indoors or to do quick basic floorplans and I did not require the accuracy you do. Nothing against lasers but also look at sonic and even GPS measuring devices. They use GPS now to plumb skyscrapers.
Please post what you decide to get. I am curious.
taking part a Laser Level pwilson2011 Tools 1 09-30-2011 09:57 PM
one service main two meters danadude1 Electrical 15 02-28-2010 01:17 AM
Problems with laser levels Plastic Brick Building & Construction 16 06-06-2009 03:46 PM
Laser Level - Eyewear Required? mfleming Safety 19 01-05-2009 11:09 PM
GE cl200 kwa meters protechplumbing Electrical 15 09-23-2008 12:10 AM
