Ladder Leveler - Best For The Least $$ ? - Tools - DIY Chatroom Home Improvement Forum
Old 04-27-2010, 11:04 AM   #1
Ladder Leveler - best for the least $$ ?
We have a 2 piece Aluminum extension ladder - 22' (I think). A roofing guy came by last week and had levelers installed on his ladder.
Curious about what anyone might recommend as a good quality inexpensive leveler? I've seen them priced from $39 to $200 for a pair. Some have just a small foot print, other look like an actual full-size extension of the ladder ... Any suggestions would be appreciated. Thanks
cody21 is offline   Reply With Quote
Old 04-27-2010, 11:10 AM   #2
I use plywood pieces, 0.5", 1" and 2" thick.
Stack them and clamp them to get 0.5", 1", 1.5", 2", 2.5", 3" and 3.5".
For finer increments add a 0.25" thk piece. A piece this thin should be Masonite or metal.
0.5" under one leg of a 22' lg, 1' wide ladder will move the top of the ladder ~1'.
Old 04-29-2010, 04:00 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I live in a hilly section so I bought the automatic levelers. to use on steps or on any non level surface the ladder is just lifted so both feet are off the ground and held to where the ladder is vertical where both feet drop down automatically to ground. This type Leveler is bolted to the ladder rather than using temporary clamps.
http://www.amazon.com/Werner-PK80-2-...ref=pd_cp_hi_2
The manual adjust levelers for around $40 should work OK if they are used most frequently on a level surface.
http://www4.shopping.com/-ladder+leveler+tool
Ladder Leveler - best for the least $$  ?-ladder-leveler.jpg   Ladder Leveler - best for the least $$  ?-ladder-level-2.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-29-2010, 08:47 AM   #4
Thanks !
Old 04-29-2010, 08:50 AM   #5
i got to say that full extended one looks weak in cross section vs the ladder itself
The older I get the better I was
Old 04-29-2010, 09:18 AM   #6
It's probably a solid piece - same strength as an "I" cross section, and maybe a different alloy.
Framing an opening for an attic ladder stubits Building & Construction 3 02-07-2010 07:12 PM
decaying floor leveler toolbelt Tina Tiling, ceramics, marble 8 09-14-2009 04:02 PM
Roof Hook w/ Folding Ladder. Good Idea / Bad Idea? jjohanson Roofing/Siding 2 10-17-2008 07:45 PM
installing a ceiling ladder jerry1967 Carpentry 6 11-20-2006 11:18 PM
