Kreg Jig - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 08:57 AM   #16
Meep!
Joe Dirt's Avatar
We have a Kreg unit at work, and use it all the time in case building. It's definitely all that... We use the blue corrosion-resistant screws...
Joe Dirt is offline   Reply With Quote
Old 01-16-2012, 09:32 AM   #17
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
The Blue-Kote Kreg Pocket Hole Screws are Zinc plated with some additional layers. They are not recommended for ACQ or other pressure treated lumber.
Click on 'Product Information' at this Link:
http://www.mcfeelys.com/product/0824...et-Hole-Screws
Stainless Steel Pocket Hole Screws are available from many sources but they are expensive.
e.g. http://www.mcfeelys.com/product/0812...tainless-Steel
Disclaimer
& Stay Safe
.....Bob Lavery
Old 01-16-2012, 06:59 PM   #18
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,250
are you sure they arent epoxy coated just like deck screws only blue?
woodworkbykirk is offline   Reply With Quote
Old 01-16-2012, 08:28 PM   #19
Meep!
Joe Dirt's Avatar
Here is the page for the blue-kote screws... We don't use any pressure treated lumber at work, it's all MDF, Medex, Baltic Birch/multiply, or plywood.
Old 01-17-2012, 12:16 AM   #20
Tool Geek
PaliBob's Avatar
How good! is Blue-Kote?
The answer is that they are much much better than untreated screws but they are NOT recommended for pressure treated wood.
Below is the Mfg "Product Information" from Post #17 of this thread:
"Blue-Kote ™ Kreg Pocket Hole Screws feature a three layer high-grade anti-corrosion coating. The first layer is a zinc layer to protect the hardened steel inner screw from corrosive environments. The second layer inactivates the zinc and creates adhesion between the base coat and the Blue-Kote layer. The Blue-Kote layer is a baked ceramic which is electrically/chemically inert, so rust can’t form on the surface. Enough of all that chemical talk, the gist is that the Blue-Kote pocket hole screws are 400% more weather resistant than the “old” Sun-Seal Kreg pocket hole screws and they still have our favorite Square Drive recess for positive bit engagement. Not recommended in for ACQ or other pressure treated lumber."
Note: Kreg implies that the blue coating does NOT impinge on the #2 square drive recess, but I have found that standard #2 bits for me are hard to seat. So I use the slightly "Undersized" #2 square drive bits similar to:
http://www.mcfeelys.com/product/HX-0...ode-Driver-Bit
The undersized #2 square drive bits used to be available in a 6" length (# HX-0262). So now I use the the 4" Driver (HX-0242) with an extender from HF:
http://www.harborfreight.com/magneti...der-36555.html
Disclaimer
& Stay Safe
.....Bob Lavery
Last edited by PaliBob; 01-17-2012 at 06:07 AM. Reason: 6" Undersized Drivers N.A.
Old 01-17-2012, 09:15 PM   #21
interesting since the kreg dealers have it listed as being acq compatible .. must be a mix up somewhere
Old 01-18-2012, 04:16 AM   #22
Tool Geek
PaliBob's Avatar
I have not seen Blue-Kote screws listed as "ACQ compatible" from Kreg or from any dealers. Can you give me a source?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 01-18-2012, 04:28 PM   #23
it was an in store display at the local busy bee tools. which is a canadian chain of woodworking supplies
Old 01-18-2012, 08:32 PM   #24
Tool Geek
PaliBob's Avatar
Thanks, I could not find it recommended for ACQ on the net.
ACQ is so much more corrosive than the pre-2004 CCA and Wolmanized treatments that I think that at least most USA suppliers are hesitant to recommend any non-stainless screws for ACQ.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 01-18-2012, 09:20 PM   #25
In a little over my head
Rewards Points: 706
This topic has perfect timing. Rockler just sent me a $10 coupon. I think I'll pick up a Kreg mini-jig kit and a box of screws this weekend.
ratherbefishing is offline   Reply With Quote
Old 01-19-2012, 05:33 AM   #26
Tool Geek
PaliBob's Avatar
Great choice, Pocket screws are used either to build new things or fix old things. This Jig can do both although for building new things the more expensive jig's have a faster set-up time for multiple holes. I use the Mini Kreg Jig for all my repairs e.g. chair rungs, and love it.
Disclaimer
& Stay Safe
.....Bob Lavery
Buying a pocket hole jig - Need advice Clemsig07 General DIY Discussions 8 06-02-2011 07:02 AM
Kreg Track System for Miter Saw Stand Klawman Carpentry 2 12-07-2009 03:22 PM
Is a pocket jig the way to go? roxksears Carpentry 25 11-30-2009 05:27 PM
Kreg K3 pocket hole kit Daveylad Carpentry 18 12-09-2008 09:01 PM
biscuit joiner helpless handyman Carpentry 13 12-19-2007 02:02 PM
