Keyed Or Keyless Chuck? - Tools - DIY Chatroom Home Improvement Forum
Old 12-21-2008, 09:44 PM   #1
Rewards Points: 820
Keyed or Keyless chuck?
Hi all;
I'm going to buy a new 1/2" corded drill. It will be either a DeWalt or Milwaukee.
The keyless chuck on some of the Milwaukees seems convenient, but will I be able to get the chuck tight enough for a standard drill bit (without the flat sides on many of the newer ones now).
I will be using a wood-boring bit or auger, and it may be at the end of a 16" extension, so everything needs to be nice and snug so it doesn't come loose when the bit starts to shake a bit.
Thanks for your advice
Ultrarunner2017 is online now   Reply With Quote
Old 12-21-2008, 10:05 PM   #2
Registered User
Termite's Avatar
On a corded drill without a clutch which aids in tightening bits in keyless chucks, I'd definately opt for a keyed chuck.
Old 12-22-2008, 07:35 AM   #3
Rewards Points: 820
Thanks for the advice. I've always used keyed chucks (except for the el-cheapo cordless) in the past.
Old 12-22-2008, 07:58 AM   #4
Eibwen
Keyless chucks are convenient for some applications but in yours I would say go with the keyed chuck.
Sammy is offline   Reply With Quote
Old 12-27-2008, 07:46 AM   #5
Rewards Points: 1,016
Keyless is the way to go for smaller drills, but for a 1/2" drill doing hefty work a keyed chuck is preferable - IMHO.
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
did i fry my hammer drill's chuck ? amakarevic Tools 5 04-15-2008 02:48 PM
How to take off this chuck? Jiffycake Tools 2 02-08-2008 09:29 PM
Keyed locks for windows, no sill plate, help! steveefer Carpentry 1 10-09-2007 11:13 AM
