Keeping Caulking Trick - Tools - DIY Chatroom Home Improvement Forum
Old 10-17-2007, 05:06 PM   #1
Rewards Points: 150
Keeping caulking trick
I discovered this by accident while doing a paint job last week.
I had to quit for a while. Using Latex caulking I looked for something to cover the tip of the tube to keep it safe. I grabbed a bolloone laying on the kids toy box, add a drop of water slid this over the tip.
Well i didn't make it back to the job for two weeks. The caulking was good as just opened.
for what it's worth
Deckhand
deck hand is offline   Reply With Quote
Old 10-17-2007, 11:06 PM   #2
kemerick's Avatar
Rewards Points: 87
I usually turn a couple inch screw into the tip and that seems to do the trick. Right before I do it I make a little ooze out so the threads are coated for proper sealing. Sometimes it has not worked but most times however I go back months later, remove the screw along with the hardened clump attached to the screw... and it works just like new.
My constant project is my home, my play time is usually spent on my CNC router.
kemerick is offline   Reply With Quote
Old 10-17-2007, 11:15 PM   #3
I use a large wire nut. Ooze a little into the nut as I screw it onto the tip, for a good seal. Works very well, and reusable.
NateHanson is offline   Reply With Quote
Old 10-17-2007, 11:17 PM   #4
kemerick's Avatar
Rewards Points: 87
That sounds like a much better seal than my idea, thanks...
Old 10-18-2007, 04:52 PM   #5
Mod / ArchiBuilder
Cole's Avatar
They also make caps for them.
Cole is offline   Reply With Quote
Old 10-18-2007, 07:51 PM   #6
kemerick's Avatar
Rewards Points: 87
True... but I would just loose that
...I got lots of wire nuts.
Old 10-18-2007, 09:51 PM   #7
Mod / ArchiBuilder
Cole's Avatar
True!
Old 10-18-2007, 10:06 PM   #8
Home Improvement Guy
ron schenker's Avatar
Now if we could just figure out a foolproof way to do this with cans of spray foam insulation...
ron schenker is offline   Reply With Quote
Old 11-15-2007, 09:53 AM   #9
Spyko's Avatar
spray foam
I've had mixed results, depending on how full the can is, but try turning the can over like you were cleaning the tip on a can of spray paint. Blow out the straw with a compressor.
Spyko is offline   Reply With Quote
tips for caulking trim?? shotdown Painting 2 08-16-2007 12:37 AM
Caulking Gun Cleaning miami vice 25 Roofing/Siding 11 05-21-2007 10:48 PM
bathtub caulking mark p Plumbing 2 02-05-2007 06:55 PM
Crown Caulking Not Sure Carpentry 3 08-18-2006 10:40 PM
caulking trim with silicone castleconcepts Painting 2 10-24-2005 12:16 AM
