-   Tools (http://www.diychatroom.com/f29/)
-   -   Keeping caulking trick (http://www.diychatroom.com/f29/keeping-caulking-trick-12485/)
deck hand 10-17-2007 05:06 PM
I discovered this by accident while doing a paint job last week.
I had to quit for a while. Using Latex caulking I looked for something to cover the tip of the tube to keep it safe. I grabbed a bolloone laying on the kids toy box, add a drop of water slid this over the tip.
Well i didn't make it back to the job for two weeks. The caulking was good as just opened.
for what it's worth
Deckhand
kemerick 10-17-2007 11:06 PM
I usually turn a couple inch screw into the tip and that seems to do the trick. Right before I do it I make a little ooze out so the threads are coated for proper sealing. Sometimes it has not worked but most times however I go back months later, remove the screw along with the hardened clump attached to the screw... and it works just like new.
NateHanson 10-17-2007 11:15 PM
I use a large wire nut. Ooze a little into the nut as I screw it onto the tip, for a good seal. Works very well, and reusable.
kemerick 10-17-2007 11:17 PM
That sounds like a much better seal than my idea, thanks...
Cole 10-18-2007 04:52 PM
They also make caps for them.
kemerick 10-18-2007 07:51 PM
True... but I would just loose that :)
...I got lots of wire nuts.
Cole 10-18-2007 09:51 PM
True! :laughing: :laughing:
ron schenker 10-18-2007 10:06 PM
Now if we could just figure out a foolproof way to do this with cans of spray foam insulation...
Spyko 11-15-2007 09:53 AM
spray foam
I've had mixed results, depending on how full the can is, but try turning the can over like you were cleaning the tip on a can of spray paint. Blow out the straw with a compressor.
