Karcher 395m - Tools - DIY Chatroom Home Improvement Forum
Old 07-05-2012, 10:28 AM   #1
karcher 395m
Wondering if anyone can tell me where the spill valve, or pressure valve is located? Can't seem to get any answers for Karcher. Machine motor keeps running when releasing trigger on gun instead of shutting down. Tech told me it was on top in control box but only valve I see is pump and would have to take it apart .. by the way this is electric.
guysr1 is offline   Reply With Quote
Old 07-05-2012, 04:12 PM   #2
Rewards Points: 1,300
I did some research for you and found this page. Not sure which part you need but I think it may be here http://www.ereplacementparts.com/kar...389_33647.html
danpik is offline   Reply With Quote
Old 07-05-2012, 06:05 PM   #3
dampic thanks for the reply I did find that before and it seems as 11 is the valve but looking at the karcher the just show bolts on front and not the ones behind to get to the valve if that is what they say it is before you get to that there are 3 sections that are bolted to one another which don't show on the diagram . Wondring if I can just take the whole section out and save all the springs and stuff from the chemical mixer. Just a poor diagram that really don't match up with the actual 395 m
Karcher Pressure washer scarrylarry Tools 6 07-29-2012 10:52 PM
Karcher Pressure Washer Leaks smata67 Tools 7 06-08-2012 07:25 PM
Karcher pressure washer fragrant_fred Electrical 8 05-20-2010 02:36 PM
