03-12-2009, 10:56 AM
#1
Just bough an old lathe - need some help
Picked up an old cast iron lathe yesterday for $25. Motor runs, has the belt, everything looks relatively clean and in working order, except:
I think the tailstock is missing the spindle, the little tapered thing that digs into the stock.
I assume these are pretty easy to find, but no idea what part I need exactly, if they are universal, etc....
Any suggestions?
I'll try to post a pic later.
Thanks.
03-12-2009, 11:21 AM
#2
the Musigician
google the make and model #
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes!
03-12-2009, 12:02 PM
#3
there is no make or model number printed on it anywhere.
it's missing the coverplate around the belt drive area, so that may have had a make printed on it.
by the looks of it i'm guessing this is from the 40s or so.
thanks.
03-12-2009, 12:26 PM
#4
the Musigician
MY next step, were it mine, would be to take the measurements of what it needs to a local steel mill here and have them create it. they'd probably not charge much to do it.
DM
03-12-2009, 12:42 PM
#5
Here's a link to standard size tapers used in machines.
http://www.newmantools.com/tech/taper.htm
I bet you've got a #2 or #3 Morse.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
03-12-2009, 12:48 PM
#6
Tail stock's are typically standard sizes and can be purchased from on-line catalogs. Post a picture of the lathe and the tail stock housing . Ideally you will want to buy an off the shelf one. It will be very accurate, better heat treating, and MUCH cheaper than buy a custome made unit. Plus, if you can figure out the correct size you can start buying other accessories to fit into the housing such as drill chucks, boring holders, etc.
Look in your phone book for any local machine tool distributors that you could bring the housing to. They likely have some tail stock parts on their shelf.
Even though the lathe is old you may still be able to buy replacement tooling. Especially if it was a more common brand. Many such as Hardinge still make and sell parts for their old products.
03-12-2009, 12:50 PM
#7
keep in mind that you want that tail stock's dimensions to be PERFECT. Surfaces need to be ground and polished very smooth. geometry such as straightness and concentricty needs to be dead nuts on if you want good machining results. Even cheap china stuff is pretty accurate.
03-12-2009, 12:59 PM
#8
Hate to chime in again. Sounds like what you are looking for is a "center". Are you looking for a live center or dead center? Are you planning on cutting wood, metal, or both.
Go to this website and search on tailstock, dead center, and live center. It will give you an idea what is out there.
http://metalworking.mscdirect.com/cgi/NNSRHMW
03-12-2009, 01:13 PM
#9
thanks beerdog.
yes, i think what i need is the "morse taper." pretty sure i need a #1 as the opening is rather small.
i will be turning wood only on this thing.
i will get you a picture later this afternoon.
thanks a lot for all the advice.
03-12-2009, 01:34 PM
#10
here are some picture of the lathe:
missing "live center?" just measured it and the inside diameter is roughly 1/4".
head stock.
obviously this sucker needs a proper bench built for it.
should wire up a switch.
everything else looks OK, right?
thanks.
03-12-2009, 01:58 PM
#11
Good find for 25$! I am not that familiar with this type of lathe. It looks like there is already an outside dead center in the tailstock. Your center would have a long taper that would slide into the tail stock and is held in place by friction. Can you pop it out of the tail stock with a pipe or wood rod from the back side. Tap it with a hammer if needed. That is the typical way to remove a center. May also be able to pop it out by sliding the lever back and forth. Here is apicture of a typical dead center. Only the pointed tip sticks out of the housing.
03-12-2009, 02:03 PM
#12
I just did a gogle search and I think you have a woodworking "cup" center without out the center pin.
03-12-2009, 02:05 PM
#13
Originally Posted by beerdog
Good find for 25$!
Agree, good find. You should have the same taper on both stocks.
You may want to make a table out of unistrut or 8020.
03-12-2009, 02:25 PM
#14
yeah, thanks. couldn't pass it up for $25, even if it didn't work. hehe.
what's the difference between a dead center a live center?
beerdog: so you're saying i need to buy a dead center for it?
thanks again.
PS: you g uys have any inkling as to how hold this lathe is and who made it?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
