Injured Using Milwaukee Cordless - Tools - DIY Chatroom Home Improvement Forum
Old 11-07-2013, 11:28 PM   #1
Rewards Points: 99
Injured using milwaukee cordless
Don't know anyone else has been hurt using their small M12 Milwaukee drill but I sure was yesterday.
I was holding the chuck in place while installing a bit and the knurled surface of the chuck grabbed the webbing between my thumb and index finger and wedged it under the plastic cover the goes over part of the chuck. It ripped all the skin off. The pain was excruciating. Good thing the homeowner wasn't there to hear me scream. I would have taught them a few 4 letter words they probably never heard before. Really looks like a dangerous design flaw.
kirwinjd is offline   Reply With Quote
Old 11-07-2013, 11:37 PM   #2
Dave88LX's Avatar
Rewards Points: 564
I thought you weren't supposed to do it that way "technically". I know we all do. Hope you heal well, that's a sucky place to have to rebuild all your skin!
Dave88LX is offline   Reply With Quote
Old 11-08-2013, 01:15 AM   #3
Rewards Points: 99
Thanks for the response.
I don't know how else to tighten a drill bit in a keyless chuck but if there is another, safer way please share. I'm not fond of having to pull my own flesh out of a drill while bleeding profusely.
Old 11-08-2013, 07:51 AM   #4
PoleCat's Avatar
Rewards Points: 1,646
An ouchie like that warrants inventing new cuss words!
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-08-2013, 08:59 AM   #5
Rewards Points: 736
I don't really understand what the design flaw is, don't all of those keyless chucks have a gap between the part you hold and the spinning part? Is the Milwaukee one just particularly big?
TheBobmanNH is offline   Reply With Quote
Old 11-08-2013, 09:33 AM   #6
PoleCat's Avatar
My have just been a perfect storm of grabbing it in the wrong spot.
Old 11-08-2013, 09:34 AM   #7
Gymschu's Avatar
Rewards Points: 462
I've not done what you described, but, I sure mangled my hands up when a spade bit gets bogged down and catches in the wood and twist the drill, slamming the drill and your hand against the piece or pieces you are working on……..painful.
Gymschu is online now   Reply With Quote
Old 11-08-2013, 10:36 AM   #8
Dave88LX's Avatar
Rewards Points: 564
I have keyless chuck drills too. I use the trigger to close the chuck enough to hold the bit. If you twist the forward part of the chick with the drill off, it locks and and you can turn it as tight as you need it.
Old 11-08-2013, 02:43 PM   #9
Rewards Points: 99
It's hard to describe how it's designed so all I can say is there is a small gap between the spinning chuck and the body of the drill. It's just enough to pull loose flesh into the gap as the knurled chuck tears it to pieces all within a micro second.
The biggest problem is that I'm trying to tighten the bits as much as possible. They seem to always come loose while I'm drilling that's why I've been holding onto the chuck while pulling the trigger.
Old 11-08-2013, 02:44 PM   #10
Rewards Points: 99
That's a cuss word?? Wish I could use that instead of the other things I said. Guess I need to practice that one for future injuries.
Thanks a lot!
Old 11-08-2013, 02:50 PM   #11
Rewards Points: 99
That has happened to me as well on numerous occasions.
Kens rule of law: (that's me)
The odds of a high torque drill twisting your hands against an object are in direct proportion to the sharpness of that object.
Old 11-08-2013, 04:19 PM   #12
Mad Scientist
And working with a dull hole saw in a tight spot is a great way to find out what a Makita battery pack tastes like... Not that I would know
On the actual subject, I admit I pretty much always tighten the chuck on my Makita drill "under power" but it's never grabbed me. There's a pretty wide gap on this drill though, probably 3/16" or so. Might also have to do with the position of your hand, too.
McSteve is offline   Reply With Quote
Old 11-09-2013, 07:03 PM   #13
Rewards Points: 81
I do as this guy suggests. You can get the bit way tighter this way. Also, if you don't want to bump or twist your wrist when hole sawing, why not use that handy side handle that comes in almost every kit (that always gets lost because you don't use it).
one cut is offline   Reply With Quote
cordless drill selection help needed JackB Tools 30 10-24-2012 08:04 PM
Milwaukee cordless hammer drill - keyless chuck screw stripped eclark Tools 5 09-11-2012 12:46 PM
Help choosing between these cordless power drills and why for a 1st timer? amlodipine Tools 21 09-24-2011 12:23 AM
Milwaukee M12 cordless drill/driver/hammer drill - enough for the job? snosurfa7 Tools 8 12-05-2010 10:51 PM
Circular saw -- 6 1/2" Vs 7 1/4" & cordless Vs corded whataboutj Tools 9 02-26-2010 05:20 PM
