Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 09-21-2012, 10:32 PM   #1
Infrared Thermometer Minimum Distance to Target?
Considering buying an Extech 42510A Infrared Digital Thermometer.
Distance to target ratio is 12:1. Anyone know is there's a minimum distance to target or will it work for anything in between 12" and 1" of distance from target? Actually, I'm not anticipating needing a measurement of anything small enough to require only an inch of distance from target, just curious. Probably wouldn't need anything smaller than a 1/2" diameter beam. But then again, I've heard you discover all sorts of uses for them after buying one.
Saw nothing on the product page about this at Extech's site.
justplumducky is offline   Reply With Quote
Old 09-21-2012, 11:02 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Arm's length is best way to judge. In other words, 2-3 feet, depending on the person.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 09-21-2012, 11:28 PM   #3
Greg~, I don't get your meaning. I'm wanting to know if the gun can be held as close as one inch from a target, which would make the laser beam diameter 1/12 of an inch in diameter (or just a bit under 3/32"). This gun's distance-to-target ratio is 12:1.
Not really anticipating needing a beam diameter that small (maybe 1/2" diameter), but they say you find all sorts of uses after you buy one.
Thx for your reply.
Old 09-22-2012, 01:23 AM   #4
Tool Geek
PaliBob's Avatar
Originally Posted by justplumducky View Post
.....is there's a minimum distance to target.......
There is no Minimum distance but for maximum accuracy there is a maximum distance that is dependent on the circular area of the target being measured. Just how much the fan shaped detection beam actually fans out can be approximated with a little DIY experiment:
  • In a warm room.take a glassof water with
  • A couple of inches of crushed ice (not cubes) added
  • Center the laser pointer over the top center of the glass
  • When the laser pointer is just above the ice bath, it should read 32 Deg
  • Slowly increase the distance above the glass until the reading jumps >32
  • This is the height where the detector cone is wider than the glass
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
ratherbefishing (09-24-2012)
Old 09-22-2012, 09:40 PM   #5
Very cool - thank you PaliBob!
Old 09-23-2012, 11:14 AM   #6
i just checked my RAYTEK. from 12' to touching the wall = 0 change.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 09-23-2012, 11:52 AM   #7
Tool Geek
PaliBob's Avatar
The Pali-test is not going to work on the wall. The purpose of using an ice bath in a confined target area (diameter of the glass) against a warm background is that initially the detection area is limited to the ice bath but then as you draw farther away the detection cone area starts to pick up more and more of the warm background so that the IR Thermometer reads increasingly above 32 deg although the laser pointer is still centered on the ice bath.
& Stay Safe
.....Bob Lavery
Minimum distance from floor to bottom of baseborad heat outlets Romeo100 HVAC 2 05-17-2012 05:50 PM
Infrared Thermometer - is the Dewalt 12V necesary? whataboutj Tools 0 07-04-2011 11:20 PM
Minimum distance from ground for load center. The Mindz i Electrical 52 03-16-2011 12:46 AM
Minimum distance from furnace vent to bathroom fan vent? pttcc HVAC 1 08-25-2010 09:54 PM
Which Infrared Thermometer displays spot outline? Michael Thomas Tools 2 12-28-2009 10:54 AM
