Inactive Compressor - Tools - DIY Chatroom Home Improvement Forum
Old 11-20-2013, 07:06 PM   #1
Inactive Compressor
I bought a used Sears Craftsman compressor which has not been used for three months. Is there anything I need to check or change before I start it up for the first time?
rhaley is offline   Reply With Quote
Old 11-20-2013, 09:44 PM   #2
DIY staff
Rewards Points: 7,174
If it's an oil bath compressor---check the oil level---change it if the compressor is ancient--drain the tank of any water--
-other than that--pug it in and see if it works----3 months sitting is not a long time.
Old 11-20-2013, 09:44 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
is it oil less? if it requires oil i would change that first just to be safe.. make sure its turned off when you plug it in because it can cause the reset on it to trip
woodworkbykirk is offline   Reply With Quote
Old 11-21-2013, 04:47 AM   #4
raylo32's Avatar
Rewards Points: 1,254
My 10 year old Craftsman compressor only gets run a few time a year. 3 months (or longer) is a very typical period of inactivity for mine. As mentioned above open the bottom drain to get out any water (hopefully the previous owner did that) and then make sure the drain is shut, and you should be good to go.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 11-21-2013, 02:24 PM   #5
i actually leave the valve open on my compressor when its going to be store for some time .when you bleed the tank not all the water comes out.. by leaving it open it can still be able to dry out
Air Compressor Fittings - Differences? roasted Tools 3 09-19-2012 08:15 PM
Help assembling compressor jfhspike Tools 5 03-27-2011 10:07 AM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
Please help: blown fuse, slow compressor fan, and hissing noise from compressor frazwr01 HVAC 10 06-27-2010 09:08 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
