Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 03-06-2013, 12:19 PM   #1
Impact driver wobble bit
I bought the Ridgid drill/driver combo R9600 about 5 months ago. Been using mostly the driver and hardly the drill.
Recently I noticed the driver is making more noise when driving (more than before). If I put in a long bit (say a 3" bit) and turned it on and see it spinning in the air, I can clearly see a "wobble" about 1/4" at the tip.
Same bit, inserted into the drill, and turned it on, no wobble at the tip.
I know a drill with a tightened chuck should be truer then the driver with a quick release mechanism.
I *think* this wobble wasn't there before. I am not 100% sure. I never dropped the tool.
The question is how much wobble is too much?
Is a 1/4" side to side wobble at the tip of a 3" bit TOO MUCH? Or ACCEPTABLE?
Oh, I checked the bit, it's straight. I also tried a few other longer, shorter new, never been used bits, same results. So it's not the bit.
miamicuse is offline   Reply With Quote
Old 03-06-2013, 02:47 PM   #2
Sounds like something is loose. It probably won't wobble if you are actually using it to drive in a screw but it might transfer a lot of vibration to your hand. I'd try it on a piece of scrap. If it doesn't feel right, call Ridgid and set up an exchange, IMO.
jeffsw6 is offline   Reply With Quote
Old 03-06-2013, 09:41 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
mis aligned chuck by the sounds of it. its common with impacts.. as for the noise.. i was talking to their rep back in december when i was buying some new drills. he said they have had several of the newest ridgid impact come back defective.. mostly problems with them overheating
woodworkbykirk is offline   Reply With Quote
Impact Wrench vs Impact Driver piste Tools 8 01-15-2013 10:22 PM
Ridgid Impact Driver - Learning how to use one miamicuse Tools 8 06-19-2012 08:02 AM
Is there a 'Quiet' impact driver? walkman Tools 7 05-06-2012 03:14 PM
12-Volt Impact Driver vs 18-Volt Impact Driver for Building a Deck mdawson3k General Discussion 11 06-28-2011 08:16 AM
Picked up my first impact driver ajtool Tools 8 10-31-2010 12:23 PM
