Impact Driver - Why? - Tools - Page 5 - DIY Chatroom Home Improvement Forum
Old 01-19-2011, 03:08 PM   #61
Mold!! Let's kill it!
Rewards Points: 2,012
Getting back to the OP's original question of why. Because you can build a 12x20 pressure treated deck and end with the same phillips bit that you started with. Because you can build that deck without camming out any screw heads. Because it will run the lag screws in just as easily as the coated deck screws. And because it is one more cool tool to own and your brother-in-law can drool over.
Old 01-19-2011, 03:23 PM   #62
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 690
This is really the best answer in the whole thread.
hyunelan2 is offline   Reply With Quote
Old 01-19-2011, 03:44 PM   #63
A Little Of Everything
Rewards Points: 1,364
You, my friend, are a real man!
DrHicks is offline   Reply With Quote
Old 01-19-2011, 04:22 PM   #64
Rewards Points: 152
Well there certainly is a lot of conflicting information out there on how these things work....
http://www.doityourself.com/stry/how-does-an-impact-driver-work
http://impactdriver.org/
There are a number of sources that state that a downward force is applied..others are silent on the point...and I haven't found one yet that explicitly states NO downward force is applied. However, the many posts in this thread stating that no downward force is applied cannot be ignored ...despite the fact that, just like Wikipedia, anyone can add to the thread...and unlike wikipedia there is no content accuracy oversight. Does that make this thread LESS credible than Wikipedia? I don't think so. To remove any doubt I spoke with Makita and confirmed that impact drivers and impact wrenches basically work the same way...just different interfaces to bits/sockets, variations in torque, etc. I stand corrected from my prior statements regarding downward force being applied with impact drivers.
Lastly, and back on track to the OP...I have the Makita 18V impact driver and find it to be a great tool. But I also do a lot of my own automotive work and am considering picking up their impact wrench as well.
PS. So who is going to update the Wikipedia entry on impact driver functionality? After all..anyone can edit...
piste is offline   Reply With Quote
Old 01-19-2011, 04:28 PM   #65
....Because you can build a 12x20 pressure treated deck and end with the same phillips bit that you started with. .....
And, if you were using a #2 Robertson bit and screws, you could probably start and end the summer with the same bit.
Fishroom is offline   Reply With Quote
Old 01-19-2011, 06:13 PM   #66
Tom Struble's Avatar
Rewards Points: 2,002
Originally Posted by beerdog View Post
The downward force is intened for breaking loose siezed or rusted fastners. It is a very effective technique. Obviously, it is a technique used more often in mechanical work than wood contruction work.
yea but its got nothing to do with what we were talking about
Tom Struble is offline   Reply With Quote
Old 01-19-2011, 06:16 PM   #67
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
I'm glad that got resolved. Just to add a couple thoughts...if an impact hammered, you would have a hard time keeping the driver bit on the screw or the socket on the nut. Hammer drills do apply the downward, or axial force, to aid in busting through hard materials like brick and concrete. Wiki is an interesting source of knowledge, but I always wonder how much truth it contains. It's really just a collaborative rumor mill. Your only hope is that someone knowledgeable comes along and corrects the non-truths. Maybe I'm too skeptical.
WirelessG is offline   Reply With Quote
Old 01-19-2011, 07:55 PM   #68
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I liked this part better:
Old 01-19-2011, 08:01 PM   #69
nap
You talking to me?
nap's Avatar
piste;573907]..and I haven't found one yet that explicitly states NO downward force is applied.
yes you have; ME. I went and checked mine twice just because of this thread, although I was certain I was correct before I checked.
that's a Hell of a man to come back and admit it. You get a from me.
Old 01-19-2011, 09:08 PM   #70
Rewards Points: 152
Just the way I am. But I'll go one better than that...let's see if it sticks...third paragraph last sentence...and paragraph four....http://en.wikipedia.org/wiki/Impact_driver
Old 01-20-2011, 06:40 AM   #71
Old 01-20-2011, 09:55 AM   #72
Rewards Points: 150
http://www.sears.com/shc/s/p_10153_1...1&blockType=G1
This is the impact driver that is being confused with a cordless impact driver in this discussion. Wiki just doesnt have it right this time.
STL B. is offline   Reply With Quote
Old 01-20-2011, 11:56 AM   #73
I, too, think wikipedia has it wrong in this case. I have a dewalt and rigid impact driver. Neither applies a downward force as near as I can tell. Neither did I expect them to do so.
I have always understood such tools to be called "hammer" drills, as opposed to "impact" drills/drivers/wrenches. One can definitely feel the downward impulse forces of a hammer drill and this is not present on any of the impact tools that I own. I would dare say that the hammer action would actually be detrimental to installing a screw...I suspect it would knock the tool bit OUT of the screw head.
Yes, my brother-in-law drools over these tools.
oberkc is offline   Reply With Quote
Old 01-20-2011, 12:08 PM   #74
Rewards Points: 152
This is the impact driver that is being confused with a cordless impact driver in this discussion. .
Yep...I own that one in addition to my cordless Makita.
It does now.
Old 01-25-2011, 11:27 PM   #75
I recently drilled approximately 50 holes with my Makita BTD141 and a couple Irwin Speedbor bits (http://www.amazon.com/Irwin-Industri.../dp/B000LQ905E) through 120-year-old 2-3 inch studs and joists for a wiring project.
To use an old and tired saying, it was just like a hot knife through butter. I hate to think what my wrist would feel like if I'd used a regular drill. The impact action of the driver sends the bit through the wood without transferring any torque to the user. Never once did the impact driver twist in the hole and wrench my wrist.
Great tool, wish I'd had one 20 years ago.
itin1200 is offline   Reply With Quote
Impact Wrench vs Impact Driver piste Tools 8 01-15-2013 09:22 PM
Bosch PS41 12V Impact Driver PaliBob Tools 0 11-01-2010 12:25 PM
Picked up my first impact driver ajtool Tools 8 10-31-2010 11:23 AM
Small impact driver vs. driver/drill Shrute Tools 17 05-02-2010 11:49 PM
Makita Impact Driver vs Wrench HELP! the496rocket Tools 8 02-14-2006 07:41 PM
