Impact Driver For Mixing Thinset? - Tools - DIY Chatroom Home Improvement Forum
Old 09-14-2012, 01:53 PM   #1
Amateuralex's Avatar
Rewards Points: 270
impact driver for mixing thinset?
I need a new drill and I was wondering if there was an any reason that an impact driver wouldn't be good for mixing thinset?
Amateuralex is offline   Reply With Quote
Old 09-14-2012, 02:25 PM   #2
bbo
do they even make the mixing attachments with the impact driver end? most impact drivers i see are only 1/4 inch.
bbo is offline   Reply With Quote
Old 09-14-2012, 02:40 PM   #3
Rewards Points: 270
Ah good point!
Old 09-14-2012, 02:43 PM   #4
bbo
i just bought an on sale 1/2 drill from Sears to use for mixing mud.
Old 09-14-2012, 02:45 PM   #5
Rewards Points: 270
Yeah I think it's time to just get a corded electric drill for this to stop worrying about batteries etc. They look pretty cheap. I won't use them for much else but whatever. I have 13 more bags of thinset to mix for this project so this alone is worth the 30-40$ for a corded drill.
Old 09-15-2012, 11:03 AM   #6
Rewards Points: 216
there are now 2 completely different tools, with the same name sheeesh.
Fix'n it is offline   Reply With Quote
Old 09-15-2012, 11:06 AM   #7
Rewards Points: 13,246
Going to need a 1/2 HD drill for this one unless you want to burn it up before your done with the job.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
woodworkbykirk (09-19-2012)
Old 09-15-2012, 11:14 AM   #8
Not so new
12penny's Avatar
Rewards Points: 520
Agreed, been there done that. Regular 1/2" drill doesnt have the torque.
12penny is offline   Reply With Quote
Old 09-15-2012, 04:47 PM   #9
Get a low speed (450,500,550rpm) 1/2 inch spade or D handle drill. I have a Milwaukee 1663-20 450rpm 7 amp spade handle drill w/ speed dial that adjusts to 115rpm to 450rpm. Around 225 works well for driveway sealer,thinset etc. I have a big 8 amp Porter Cable model 7554 variable speed 0-500rpm d handle that would make a great mixer too! The big D handles and spades run alot cooler under heavy loads then pistol grip 1/2 inch drills. Drilling out a tree stump w/ a 1 1/2 auger bit makes the big Milwaukee and Porter Cable drills run only slightly warm! I once mixed some concrete resurfacer w/ my Makita 6302H 6.5 amp 0-550rpm drill. It did the job but labored a little bit. The PC and Milwaukee mix effortlessly.
toolaholic is offline   Reply With Quote
Old 09-18-2012, 11:12 AM   #10
Rewards Points: 121
I have had good results mixing mortar with this drill: http://www.harborfreight.com/power-t...ill-93632.html
jrepp44 is offline   Reply With Quote
Old 09-18-2012, 12:08 PM   #11
Nice affordable choice!
Old 09-19-2012, 06:56 AM   #12
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I use an old Craftsman to mix mud. I recently replaced the original 1960's blow molded case whose original hinges fell apart on the first use with a huge Flambeau case that's got plenty of room.
I got the new yellow Flambeau case from Sears.
impact driver for mixing thinset?-flambeau-top.jpg   impact driver for mixing thinset?-mudmixer-2.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-19-2012, 09:20 AM   #13
Best thing about your drill PaliBob is the long pipe handle. Milwaukee uses a long one on their spades. The long handle goes a long way toward controlling the kickback from stalling and drill bit binding/hitting knot etc.
Old 09-19-2012, 08:59 PM   #14
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
if you try to use a cordless to mix mortar youll burn up the mortar before its half mixed. if its craftsman it will burn up in seconds
pick up a d handle drill as mentioned or rent one. its the tool used by all proffesional tile installers and drywall finishers for mixing
woodworkbykirk is offline   Reply With Quote
Old 09-23-2012, 12:37 AM   #15
Rewards Points: 12
Is there a list of good mixing drills to use for mud and etc? I'm looking for one for a reasonable price, that means old and/or used. I googled the aforementioned tools, and they are out of my price range atm.
I bought the HF one and it burnt up after only 30 seconds. I took it back for a refund.
F350 is offline   Reply With Quote
Impact Wrench vs Impact Driver piste Tools 8 01-15-2013 10:22 PM
Ridgid Impact Driver - Learning how to use one miamicuse Tools 8 06-19-2012 08:02 AM
Is there a 'Quiet' impact driver? walkman Tools 7 05-06-2012 03:14 PM
12-Volt Impact Driver vs 18-Volt Impact Driver for Building a Deck mdawson3k General DIY Discussions 11 06-28-2011 08:16 AM
Picked up my first impact driver ajtool Tools 8 10-31-2010 12:23 PM
