impact driver for mixing thinset?
I need a new drill and I was wondering if there was an any reason that an impact driver wouldn't be good for mixing thinset?
i just bought an on sale 1/2 drill from Sears to use for mixing mud.
:eek: there are now 2 completely different tools, with the same name :laughing: sheeesh.
Going to need a 1/2 HD drill for this one unless you want to burn it up before your done with the job.
Agreed, been there done that. Regular 1/2" drill doesnt have the torque. |
I have had good results mixing mortar with this drill: http://www.harborfreight.com/power-t...ill-93632.html
2 Attachment(s)
I use an old Craftsman to mix mud. I recently replaced the original 1960's blow molded case whose original hinges fell apart on the first use with a huge Flambeau case that's got plenty of room.
I got the new yellow Flambeau case from Sears. |
if you try to use a cordless to mix mortar youll burn up the mortar before its half mixed. if its craftsman it will burn up in seconds
pick up a d handle drill as mentioned or rent one. its the tool used by all proffesional tile installers and drywall finishers for mixing |
Is there a list of good mixing drills to use for mud and etc? I'm looking for one for a reasonable price, that means old and/or used. I googled the aforementioned tools, and they are out of my price range atm.
I bought the HF one and it burnt up after only 30 seconds. I took it back for a refund. |
| All times are GMT -4. The time now is 11:58 PM. |
