Impact Driver Bits - Tools - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 06:26 AM   #1
Rewards Points: 47
impact driver bits
What do most of you use in your impact drivers? I am referring to the 18 volt handheld type and specifically torx and phillips bits. thanx
jeffs55 is offline   Reply With Quote
Old 06-03-2011, 08:09 AM   #2
I use no bits that are unique to an impact driver...I use the same ones that I would use in a drill or hand tool.
oberkc is offline   Reply With Quote
Old 06-03-2011, 09:17 AM   #3
In a little over my head
Rewards Points: 706
For turning in Deckmate screws, I've had the best luck using the Phillips and Torx bits from Deckmate. For #2 Phillips drywall screws, I've found it best to match the bits to the screws. There's enough variation in the bits/slots. For other sizes of Torx, try to find American made bits and buy some spares. It's a good fastener, but the bits don't last, IME.
ratherbefishing is offline   Reply With Quote
Old 06-05-2011, 12:41 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
McFEELY"S
For Phillips & square drive bits, I have had good luck with McFEELY"S
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-05-2011, 11:28 AM   #5
Oldguy
Rehabber's Avatar
The "gold tip' bosch bits at Lowes work pretty well
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 06-05-2011, 10:33 PM   #6
firehawkmph's Avatar
Rewards Points: 1,800
I was using regular phillips bits and had problems with them snapping off when running deck screws into subflooring. I switched to dewalts phillips bits which are labeled for impact use. They seem to be working out a lot better. Haven't broken one yet.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 06-06-2011, 11:10 PM   #7
Mike Hawkins
I had the same problem Mike. Went through a dozen just regular bits I had in the tool box and literally broke everyone. Didnt round any off but instead broke all the tips off. Bought a set of the Dewalt Impact Ready ones and am still on the first bit 6 months later.
Cmudr1 is offline   Reply With Quote
Old 06-08-2011, 10:50 PM   #8
Not a Noob or Boob
I use an impact nearly everyday. Pretty much any brand labeled for impact use will due. I am a Bosch man, so I buy Bosch when I see them, but I also have some DeWalt and Irwin in the bag as well.
Rob1975 is offline   Reply With Quote
Impact Wrench vs Impact Driver piste Tools 8 01-15-2013 10:22 PM
Impact bits and impact bit sets. MooseWoodworks Tools 3 03-25-2011 12:37 PM
Dewalt impact nut driver bits? koodawg Building & Construction 4 12-12-2010 10:55 AM
Picked up my first impact driver ajtool Tools 8 10-31-2010 12:23 PM
Small impact driver vs. driver/drill Shrute Tools 17 05-03-2010 12:49 AM
