Impact Drill Vs Regular Drill - Tools - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 05:57 PM   #1
Rewards Points: 47
impact drill vs regular drill
I have a Milwaukee 28v hammer drill/driver which works great. Do I have anything to gain from the purchase of an impact drill /driver solely for driving screws? thanx
jeffs55 is offline   Reply With Quote
Old 04-19-2011, 09:02 PM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 690
A big hammer drill is for drilling. The impacts it generates are more up/down against the bit, whereas an impact driver is more lateral with its impacts, like a pneumatic impact wrench. I would say a nice, small 10-12v LiIon driver would give you much more versatility than that big 28v hammerdrill.
hyunelan2 is offline   Reply With Quote
Old 04-19-2011, 09:38 PM   #3
Rewards Points: 78
Removed... misread the question.
Old 04-22-2011, 02:46 PM   #4
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
I agree with hyunelan2. An impact drives screws more easily than a regular drill, however they don't come with any kind of clutch that I am aware of, so you need to be careful as you don't drive it too far.
WirelessG is offline   Reply With Quote
Old 04-22-2011, 05:40 PM   #5
I was in the same situation. I have a Milwaukee v28 hammerdrill and various 18 volt screw guns. And after lugging my hammerdrill around for years a fellow carpenter slipped me his impact to try out. I was hooked after one 3" deck screw. The difference is night and day in both production and fatigue. I had a brand new Makita shortly after that. If you do alot of driving they are worth every penny!
Chevy85 is offline   Reply With Quote
Old 04-22-2011, 07:48 PM   #6
Rewards Points: 150
Lots to gain, they are screw runnin little mo-fo's. Buy one you wont regret it they rock, after you use it for a day you will wonder why they did'nt sell these things 10-20 yrs ago.
STL B. is offline   Reply With Quote
Old 04-22-2011, 07:59 PM   #7
Rewards Points: 47
But what about the issue with the torque? I mean if there is no torque setting on an impact driver. The Milwaukee has a torque setting so it will not drive a screw through a board. thanx
Old 04-22-2011, 08:25 PM   #8
Rewards Points: 150
Dont worry about having too much torque, you will learn on the second screw how you need to feather the trigger. Plus the lower the rpm the less torque it applies to the screw I use mine to put face plates on switches and outlets and havent broke one yet...................but you could run a 4" screw all the way thru a 4x4(with a 9.6-10V impact) if you wanted to.
Old 04-22-2011, 09:17 PM   #9
Love for Construction
<*(((><'s Avatar
Let's not get carried away here...
-luke-
<*(((>< is offline   Reply With Quote
Old 04-22-2011, 09:30 PM   #10
Rewards Points: 150
Beleave me if you want, But I've done it just for giggles with a makita 10.something lots of times. To be honest I've only done that with 3" drywall screws and that little makita impact would suck a screw clear thru a 4x4 or stack of 2x's
The Following User Says Thank You to STL B. For This Useful Post:
Tom Struble (05-04-2011)
Old 04-22-2011, 09:37 PM   #11
hyunelan2's Avatar
Rewards Points: 690
I drove a 3" drywall screw almost all the way through 2 2x4s - it stopped once the threads had nothing to hold on to. Hitachi 10.8v LiIon driver.
Old 04-22-2011, 09:42 PM   #12
Learning by Doing
Leah Frances's Avatar
My old house has lots of rock-hard old lumber that I have to drive screws in (or drill holes in). Without my impact driver I'd still be pre-drilling for every screw I wanted to put in.......
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-04-2011, 03:06 PM   #13
New Hitachi Cordless Impact Driver won't work!
Sorry, meant to start a new topic, so deleted text
milleniumaire is offline   Reply With Quote
Impact drill Hudnall18 Tools 18 12-05-2010 09:30 PM
Picked up my first impact driver ajtool Tools 8 10-31-2010 11:23 AM
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
