I Need A Very Very High Quality Masonry Bit - Help Needed Badly. - Tools - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 08:20 AM   #1
The Moose is loose.
MooseWoodworks's Avatar
I need a very very high quality masonry bit - Help Needed badly.
I'm hanging wood paneling over plaster walls in my living room. I'd like to avoid removing the plaster as it is very solid and would add a lot of cost to my living room project. The masonry bits I purchased from Home Depot aren't cutting. They are burning up after drilling one hole.
I need a source for some serious kick ass masonry bits. Do you guys know any manufacturers that make a masonry bit designed for heavy hardcore use?
MooseWoodworks is offline   Reply With Quote
Old 03-10-2011, 08:29 AM   #2
Rewards Points: 558
did you buy these bits?
You can also try using liquid nails to secure your wood paneling to the wall as well.
epson is offline   Reply With Quote
Old 03-10-2011, 08:35 AM   #3
The Moose is loose.
I did buy those bits. And yes I am using liquid nails. About one 28oz tube per panel.
Old 03-10-2011, 08:55 AM   #4
Rewards Points: 558
Are you using a normal drill? If so that is your problem. You should be using a hammer drill…
The Following User Says Thank You to epson For This Useful Post:
oh'mike (03-12-2011)
Old 03-12-2011, 01:06 PM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by WarEagle86 View Post
...... I am using liquid nails. About one 28oz tube per panel.
Liquid Nails is a Brand name that covers scores of adhesives.
There are three types of Liquid Nails Panel Adhesives:
LN 606....Non-Solvent, (The Home Depot)
LN 710....Non-Solvent, low VOC
LN 910....Solvent
The LN 606 claims to have an Instant-grab formula if the Application Directions for Instant grab are followed so I do not see why you need to drill holes in the plaster. Also note the manufacturer claims that a 10 oz tube will hold a 4'x8' sheet so using a 28oz tube per panel should provide plenty of strength.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-13-2011, 08:28 PM   #6
Rewards Points: 5,336
I don't understand why you need a masosary bit to install paneling on a wall.
Construction adhesive and a pin nailer is all you need.
Ron
High quality airless paint sprayer? Spud Painting 2 11-11-2009 05:51 PM
High quality contact papers which looks more realistic? fredonian Painting 1 04-13-2009 10:39 AM
Paint Brand Choice - for high quality results spartan5581 Painting 7 03-31-2009 10:27 AM
Is it a waste of money to buy high quality brushes? bluefitness Painting 2 02-08-2009 05:19 PM
does high quality bargain paint exist? erica Painting 6 06-22-2005 05:53 AM
