08-07-2012, 06:04 PM
#16
Bill Kearney
I need some help drilling into a metal bolt
Had you mentioned it was on a spigot I'm guessing most folks would've said to just replace it. I certainly wouldn't have brought up the drill press notion as it would quite clearly not work for that particular task.
Have dealt with outside spigots on old houses I can tell you it's usually best to always plan to replace it. If you get any resistance, quit while you're ahead. Because once you get it loose you often discover there are no standard parts for spigots. About the only thing you can do is replace a washer (with one that'll crap out MUCH faster) or try to repack the stem (which usually leads to the packing nut breaking).
But to the job at hand, you used too large a bit. Best to use a small one and then use an extractor bit to try and work the old fastener out. An extractor usually looks like a small drill bit but with backwards threads. The idea is as you turn it counter-clockwise it digs itself in tighter, further increase the surface area on which it pushes the old fastener.
Many spigots are connected by threads. This is often by using a short segment of threaded pipe back to a tee inside the house. You have to hold the tee on the inside and then turn the spigot outside. This makes it a two man job. If you can't get to the inside, well, you're going to have to get to the inside. Drywall and plaster are not that hard to repair. And botching a plumbing job that eventually damages inside walls will teach you this, but you can learn from everyone else's mistakes instead!
The Following User Says Thank You to wkearney99 For This Useful Post:
08-07-2012, 06:05 PM
#17
Bill Kearney
Originally Posted by DangerMouse
Mine is a screw on type, easy to pop off and replace if it ever fails.
Heh, which are supposed to be easy to pop off if they're installed properly in the first place. I've rarely had that luck.
08-07-2012, 06:08 PM
#18
the Musigician
Yes, but it was ME that installed it!  Good for 50 years and more!
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes!
The Following User Says Thank You to DangerMouse For This Useful Post:
08-07-2012, 06:15 PM
#19
Civil Engineer
The key to drilling any metal is to use a bit that is very sharp, and is harder than the metal you are drilling into. Strength of the bit is almost completely irrelevant, unless you are unable to drill straight, in which case a bit that is hard but brittle can snap on you.
When a bit is referred to as a cobalt bit, that usually means the steel is coated with cobalt oxide or cobalt nitride, not that the drill is solid cobalt. Similarly, a bit that is referred to as a titanium bit is almost certainly coated with titanium nitride or a similar ceramic material, a solid titanium bit would be very expensive and would not offer any performance advantage over a coated bit. I have titanium nitride bits at home, they work well in metal, but like most bits require oil or water to keep them cool while drilling. Even titanium nitride bits, which are much harder than most steels, will dull quickly if overheated. If they are even slightly dull they don't drill worth a damn, and they are not worth sharpening, so you buy a new set of bits.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
08-08-2012, 06:59 AM
#20
That bolt probably only holds on the faucet handle.
The Following User Says Thank You to md2lgyk For This Useful Post:
08-08-2012, 10:50 PM
#21
jschaben
I put a union on mine. Do all the soldering on the bench now
To drill that I would agree with a smaller bit. I'm also not as convinced as you are that your bits are sharp. Cobalt will work well but be aware that they are very hard and also very brittle. You haven't lived till you try to get one of those out after it broke off. DAMHIKT.
John Schaben
"Where all think alike, no one is thinking very much" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
The Following User Says Thank You to jschaben For This Useful Post:
08-12-2012, 05:38 PM
#22
I have found titanium bits work well, but tend to flex alot when they are smaller. I also like cobalt bits as they have been the only thing I have been able to use to drill spring steel. My trick has always been to us a small punch to set a pilot, and while drilling, an excellent lube is transmission fluid or PB blaster works too, it helps to pull the metal away so the bit doesn't build it up on it plus prevents overheating. By the time you invest in decent cobalt bits, it would be cheaper to just replace the spigot. Easiest way is to shut off the water main, remove it from inside the house where it joins and take it to a hardware store to compare it.
There is no point in buying low name cobalt bits as they are still pricey, as I found that one cobalt bit can be as expensive as a set of titanium, but even titanium bits should drill through a screw.
Another big help is reverse thread drill bits, I use them with my screw extractors all the time.
The Following User Says Thank You to s10sleeper For This Useful Post:
08-28-2012, 11:08 PM
#23
You need a new drill it sounds like
09-01-2012, 06:07 PM
#24
Bombastic Idiot
amodoko, good thing you explained you really did want to learn about drilling into a bolt. This looked like a time when the question asked wasn't the question that should have been asked. Sure helps to explain why one wants to do something. I was in a thread the other day where OP wanted to remove lower spray arm in dishwasher. I had experience in doing that with similar model. Not difficult, but some easily breakable moderately expensive parts involved that are kinda difficult to describe without diagrams and/or a lot of verbage.My one finger typed response was more verbose than normal. Did I say easily breakable? Especially if one does not know exactly what one is doing (ahem) and did I say I had experience in removing the arm?Turned out what she really wanted to know was how to clean her dishwasher of possible mineral build up and possible glogging of spray holes. Broken $60 part vs $1 worth of vinegar and some tooth picks.
Measure twice, cut once. Look at the nail, not the hammer. Watch the fence, not the blade. If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
