I Keep Bending Blades In Recip Saw - Tools - DIY Chatroom Home Improvement Forum
Old 08-16-2010, 01:26 AM   #1
I keep bending blades in recip saw
I've been doing a lot of demo work. A recip saw is a great tool for the job, but the blades keep on bending. It's quite frustrating.
I think my cheap blades are a POS. What kind of blades are best for the job? Do they make extra thick ones that don't bend so easily?
Maybe I'm just an idiot and not using the tool right. haha. But if I can't figure out how to use a recip saw, maybe I shouldn't be doing this kinda work eh? Regardless, I'm open to any pointers.
acerunner is offline   Reply With Quote
Old 08-16-2010, 06:12 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
More than likely you are using blades that are too short and the tip is retracting too far, causing the tip to hit what you are trying to cut as it pushes forward, resulting in a bent blade. Even good blades will bend if this is the case.
Or it could be that your blade is too long, and it's striking something that's behind what you are trying to cut
Easiest thing to do is try a different length blade.
Does your saw have an adjustable shoe? make sure it's properly adjusted for the blade length and what you are cutting
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-16-2010, 07:40 AM   #3
Rewards Points: 558
To properly know what length of blade you need for your intended project you should measure the thickness of the material you are cutting and allow an additional one to two inches of length for the cutting cycle of the reciprocating saw. The saw will draw the blade in and push the blade out during its cutting cycle. If the blade is to short for the intended project it will bind within the material, bend or snap the blade. A long blade may damage material that you do not want to cut. So measure your material thickness.
epson is offline   Reply With Quote
Old 08-22-2010, 01:24 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
David Crosby wrote a great review in the latest September 2010 issue of FHB on blades for Demolition work. The Author torture tested 15 brands of recip blades that are touted as Demolition Blades. Each had its own advantages or shortcoming in Cutting speed, Durability, Flexibility, & Price.
For cutting speed David Crosby found the 'Rigid Rapid DemolitionRD4609" was much faster than what he judged the best overall demo blade, that is the:
Bosch RDN9V RDN 9 V 9 Inch 5 8 T Demolition Reciprocating Saw Blades
The specific Test results with the pro & cons of different brands can be found in the September 2010 FHB
Also at the Big Box stores
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-22-2010, 07:00 AM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 300
The only thing I may add is to try to cut holding your saw at more of a angle instead of at a 90% of your cut, also don't let the blade get pinched as that will do some bending also.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 08-22-2010, 08:03 AM   #6
DIY staff
Rewards Points: 7,174
If you are using cheap blades---The heat that builds up while cutting will take the temper right out of the blade----Stick with high quality blades,they are actually cheaper cut for cut---
I use Milwaukee--Lenox or Starrett --I've never tried the Bosch,might be a fine blade--
Vermont American and DeWalt are early failures.
Old 08-22-2010, 08:14 AM   #7
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,342
Bending blades happens. Bend it back and cut on.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
The Following User Says Thank You to Clutchcargo For This Useful Post:
DUDE! (08-22-2010)
Old 08-22-2010, 08:42 AM   #8
Enough is Enough
H. A. S.'s Avatar
It's hard to beat Bosch blades. They're tough as nails..and then some!
H. A. S. is offline   Reply With Quote
Old 08-22-2010, 08:47 AM   #9
Well, it makes my day to learn I'm not the only one that this happens to.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 08-22-2010, 10:08 AM   #10
firehawkmph's Avatar
Rewards Points: 1,864
I have used lennox blades since they started making them. I still have some in my 35 y.o. milwaukee sawzall case. The long wood blades (12") I have bent in an arc to cut at 90 degrees to the normal direction of the blade and they haven't broken or bent. When I do bend one from hitting something or short stroking it, I either bend it back with my fingers, (watch out, they get hot) or hit em with a hammer like a body man. I haven't tried the bosch yet, but I will. Next time I see the bosch rep, I'll hit him up for some.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 08-22-2010, 11:35 AM   #11
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by PaliBob View Post
[SIZE=2]
I have wondered what he has been doing since he was no longer singing with Stills and Nash or even Young for that matter.
metal saw replacable blades which Compo Tools 28 08-06-2010 06:43 PM
Which saw blades are worth sharpening? ovahimba General DIY Discussions 2 06-02-2010 05:24 PM
Saw Blades UpComingBuilder Tools 11 10-26-2009 08:23 AM
Sears 536.884351 auger blades are discontinued, no replacement MichaelLit General DIY Discussions 2 07-08-2009 06:43 AM
Miter Saw Blades \ Crown Moulding Jigs Discussion WorkOnIt Carpentry 3 06-17-2007 04:50 AM
