Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 11-27-2012, 03:39 PM   #1
Hybrid or Cabinet Saw
I've got a (good) problem. We moved and I now have a barn that will have space within it used as my wood shop. I'm a novice, but have experienced several years of knowing that I like woodworking, and want to get better at it and be able to do more. There is currently 220v in the barn, so electric is not an issue. I have between 1000-1800 to spend.
Any ideas on whether a hybrid saw or cabinet saw would be better? I'm not opposed to buying used if needed either. Thanks.
cibula11 is offline   Reply With Quote
Old 11-27-2012, 04:32 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
it depends. do you plan on staying there for a long time and will you need to move the saw around if space is limited. if your limited for space a contractor saw will take up less space and is portable. if you have the space and its dedicated buy the cabinet saw
woodworkbykirk is offline   Reply With Quote
Old 11-27-2012, 04:39 PM   #3
Space isn't a huge issue. I don't have the whole barn but a 20x10 space within the barn. I figured I could always add a base w/ wheels if I needed to move around a bit.
Old 11-27-2012, 05:30 PM   #4
Unless you are planning to build huge projects the cabinet saw is what I would go for. I'm not sure but I don't think you can make a cabinet saw mobile or would want to.
ToolSeeker is online now   Reply With Quote
Old 11-27-2012, 05:57 PM   #5
making it movable is doable. seen it done. requires a very heavy duty base and extra heavy duty casters that lock
The Following User Says Thank You to woodworkbykirk For This Useful Post:
ToolSeeker (11-27-2012)
Old 11-28-2012, 10:51 AM   #6
Thx. I know that one thing I don't want is to regret the decision I make 5 years from now....which is got me leaning towards a cabinet saw.
custom cabinet countertop dilemma: notch it or redo? mystic_cobra Carpentry 14 05-12-2011 11:35 PM
Need help! Cabinet install gone slightly wrong eemichael83 Carpentry 14 10-26-2010 04:46 PM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 12:44 PM
