How To Tell You Need A New Blade? - Tools - DIY Chatroom Home Improvement Forum
Old 04-21-2011, 11:08 PM   #1
Rewards Points: 172
How to tell you need a new blade?
10" Mitre saw. Leaves splinters of wood off the back of a 2x4. Is the blade getting dull or is this normal? It doesnt bother me, I just want to make sure.
nateshirk is offline   Reply With Quote
Old 04-21-2011, 11:11 PM   #2
Civil Engineer
Rewards Points: 4,514
Your blade may need to be cleaned. Easiest way to clean is with ammonia, soak the blade and scrub with a nylon brush. If the blade still leaves splinters, it is probably dull. If it is a steel blade, likely not worth sharpening, if carbide it may be worth sharpening.
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 05:55 AM
center flange on masonry blade tearing hughnohoo Tools 3 11-07-2010 07:39 PM
Should I attempt to bring back my blade? Piedmont Carpentry 5 09-09-2010 05:26 PM
Removing a blade from an old Craftsman Circular Saw Davem720 Tools 1 07-05-2010 10:17 PM
Using circular saw blade in a chop saw rayem723 Carpentry 5 10-27-2008 09:08 PM
