Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 03-02-2013, 09:54 AM   #1
How to tell if hammer works on hammer drill
I just got a reconditioned Bosch HD19-2 hammer drill and I can't figure out whether it's hammering in hammer mode and only spinning in twist mode. In hammer mode, I pressed the trigger part way so it's slow and I couldn't see hammering but I heard a low pitched vibrating sound in addition to the high pitched motor sound. But then I did the same thing with hammer mode off and I heard the same two sounds. I tried this on both speeds. Does this mean it's always hammering? Never hammering? How can I be sure?
Dorado is online now   Reply With Quote
Old 03-02-2013, 09:57 AM   #2
Got to put it up againt whatever it is your trying to hammer to see if it works. Just pulling the trigger will show you nothing.
If it's working you know instantly.
Old 03-02-2013, 10:00 AM   #3
Have to wait until Monday then. Building rules. But I don't know...I bet it would drill OK through wood even in permanent hammer mode.
Old 03-02-2013, 10:06 AM   #4
You do know there not great for drilling into wood right?
Old 03-02-2013, 10:10 AM   #5
There's a "drill only action" function described in the manual as there is with most hammer drills, along with instructions for drilling wood. It's factory reconditioned and the drill-only function should work.
Old 03-02-2013, 10:43 AM   #6
put a bit in it and try drilling some cement/brick. the drill will vibrate in your hand if it is working.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 03-02-2013, 11:22 AM   #7
OK, but if it vibrates even in drill-only mode I'm returning it.
Old 03-02-2013, 11:23 AM   #8
What are your plans for this tool?
Old 03-02-2013, 11:27 AM   #9
what do you think he is going to do with it ?
he's going to drill hammers
Old 03-02-2013, 11:31 AM   #10
My immediate plans are to drill through concrete, then through drywall, but I'll surely use it for wood eventually. And steel and steel mesh.
Old 03-02-2013, 11:45 AM   #11
I tested it on a brick and it works. Big difference in sound between hammer on and hammer off, but only when you touch the brick.
Old 03-02-2013, 11:50 AM   #12
journeyman carpenter
woodworkbykirk's Avatar
thats because the anvil doesnt engage unless theres pressure on the tool
woodworkbykirk is offline   Reply With Quote
Old 03-03-2013, 09:18 AM   #13
sounds like you have a good tool.
How much faster Rotary Hammer vs. my Hammer Drill kurango Tools 24 02-22-2013 10:49 PM
Rotary hammer drill KJKerns3 Tools 14 04-11-2012 05:24 PM
Sharpening Rotary Hammer Concrete Drill Bit daltinator Tools 9 02-03-2012 08:39 PM
Milwaukee 2602 Hammer Drill Specs Change? gvales Tools 3 01-01-2012 08:13 AM
Is my new hammer drill broken? darsunt Tools 13 09-16-2009 10:53 PM
