-   Tools (http://www.diychatroom.com/f29/)
-   -   How to tell if hammer works on hammer drill (http://www.diychatroom.com/f29/how-tell-if-hammer-works-hammer-drill-173371/)
Dorado 03-02-2013 09:54 AM
I just got a reconditioned Bosch HD19-2 hammer drill and I can't figure out whether it's hammering in hammer mode and only spinning in twist mode. In hammer mode, I pressed the trigger part way so it's slow and I couldn't see hammering but I heard a low pitched vibrating sound in addition to the high pitched motor sound. But then I did the same thing with hammer mode off and I heard the same two sounds. I tried this on both speeds. Does this mean it's always hammering? Never hammering? How can I be sure?
joecaption 03-02-2013 09:57 AM
Got to put it up againt whatever it is your trying to hammer to see if it works. Just pulling the trigger will show you nothing.
If it's working you know instantly.
Dorado 03-02-2013 10:00 AM
Have to wait until Monday then. Building rules. But I don't know...I bet it would drill OK through wood even in permanent hammer mode.
joecaption 03-02-2013 10:06 AM
You do know there not great for drilling into wood right?
Dorado 03-02-2013 10:10 AM
There's a "drill only action" function described in the manual as there is with most hammer drills, along with instructions for drilling wood. It's factory reconditioned and the drill-only function should work.
Fix'n it 03-02-2013 10:43 AM
put a bit in it and try drilling some cement/brick. the drill will vibrate in your hand if it is working.
Dorado 03-02-2013 11:22 AM
OK, but if it vibrates even in drill-only mode I'm returning it.
joecaption 03-02-2013 11:23 AM
What are your plans for this tool?
Fix'n it 03-02-2013 11:27 AM
what do you think he is going to do with it ?
he's going to drill hammers :laughing: :whistling2:
Dorado 03-02-2013 11:31 AM
My immediate plans are to drill through concrete, then through drywall, but I'll surely use it for wood eventually. And steel and steel mesh.
Dorado 03-02-2013 11:45 AM
I tested it on a brick and it works. Big difference in sound between hammer on and hammer off, but only when you touch the brick.
woodworkbykirk 03-02-2013 11:50 AM
thats because the anvil doesnt engage unless theres pressure on the tool
Fix'n it 03-03-2013 09:18 AM
sounds like you have a good tool.
