How Shallow Can I Adjust This Rigid Circular Saw? - Tools - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 12:28 AM   #1
Rewards Points: 660
How shallow can I adjust this rigid circular saw?
I'm looking to purchase a Rigid R3202 circular saw, 7 1/4". Can it be adjusted to cut very shallow, such as 1/4" deep? I'm looking to cut out some bad vertical siding.
darsunt is offline   Reply With Quote
Old 03-08-2010, 12:33 AM   #2
BIGRED
Rewards Points: 252
Depending on the rigidity of the foot you should be able to adjust the depth of cut infinitely. Even down to just scuffing the paint on your siding.
Grampa Bud is offline   Reply With Quote
Old 03-11-2010, 08:46 AM   #3
I have that same model saw (love it by the way!) and the shoe has very positive throw lever tension adjustments on it, not crappy wing nuts or anything like that. Those adjustments and the cast rather than stamped shoe were it's main selling points for me. Like the above poster said it can be adjusted from about 2 1/2 deep to just scratching the surface. Whatever you want!
Smitty258 is offline   Reply With Quote
Insulating Basement w/ Rigid Foam and Batt Reilley Building & Construction 4 08-03-2013 11:07 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Ryobi vs Rigid circular saw TheMiterCut Tools 1 09-21-2008 09:39 PM
Rigid Metal Straight Threads rjordan392 Electrical 2 06-24-2007 12:42 PM
