Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 01-12-2011, 05:36 PM   #1
How to Replace a blade on electric saw
Hi,
I have a Skilsaw 3305 electric table saw. I need to change the blade and I can not get the nut to move one bit.
Does any one have any suggestions?
thank you,
jean
jmdebb is offline   Reply With Quote
Old 01-12-2011, 05:44 PM   #2
Originally Posted by jmdebb View Post
Hi,
thank you,
jean
Are you turning it the correct way?
epson is offline   Reply With Quote
Old 01-12-2011, 06:01 PM   #3
Here is the manual:http://dl.owneriq.net/4/4cda02df-2da8-497c-a481-e64e51fa1342.pdf
Go to page 34
The Following User Says Thank You to epson For This Useful Post:
webdog (01-14-2011)
Old 01-12-2011, 06:13 PM   #4
Super Moderator
Try this----Make sure its unplugged---
Stand in front of the saw---place a block of wood against the front teeth of the blade
Put the wrench on the arbor nut--handle towards the back of the saw and pull,while jamming the blade with the wood block.
If you have a stuck nut--soak it with some penetrating oil--use visegrips to grab and jam the blade-(so you have both hands free)
Then use a hammer to tap the wrench --a couple of sharp blows will usually pop free a stuck nut--
(the nut loosens by pulling the in the direction that the teeth are pointing)
--Mike--
oh'mike is online now   Reply With Quote
Old 01-12-2011, 06:14 PM   #5
Super Moderator
Or go to page 34
Damn fast typists!
Old 01-12-2011, 08:03 PM   #6
the Musigician
DangerMouse's Avatar
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 01-13-2011, 12:57 AM   #7
Originally Posted by oh'mike View Post
Or go to page 34
Damn fast typists!
What can I say…
oh'mike (01-13-2011)
Old 01-13-2011, 02:48 PM   #8
oh you are too funny.. thank you very much.. i finally found a copy of the manual online and printed out page 34. it looks like i was doing something wrong, so i'm hoping to be able to try to get to it later today, thanks so much for all your help.
jean
The Following User Says Thank You to jmdebb For This Useful Post:
Electric heat prices vs. geothermal mss119 HVAC 23 04-07-2009 08:23 PM
Should i go from GAS to Total Electric HVAC & Water heater? ehoez HVAC 9 04-06-2009 09:57 AM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 09:39 AM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 08:27 PM
Electric tankless hot water heater former33t Plumbing 2 02-28-2008 12:40 PM
