How Often Do You REALLY Empty/clean Your Air Compressor? - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-29-2008, 11:55 AM   #16
www.toolsandmachinery.com
Air Compressor
We carry the Porter-Cable Air Compressors, Curtis Toledo Air Compressors, Hitachi Air Compressors, Dewalt Air Compressors, and Makita Air Compressors. We recommend you should always drain the water out of the tank after each use. If water is left in the tank, the air has a lot of moisture which collects in the tank and can rust the tank. Also check the air filter every couple of months and oil level.
Steve-
Last edited by Ed the Roofer; 09-01-2008 at 11:15 AM. Reason: Try to eliminate Your Store Site Self Promotion.
mmtools is offline   Reply With Quote
Old 09-21-2008, 09:04 PM   #17
Auto drain is the way to go,set it and forget it,your tank will last a long time,I also have a water seperator and tool oiler inline,with the auto drain on this new compressor I have never seen water in the seperator or in the exhaust of the tool..
really it's the tools that pay the price,rust inside an air tool is death
gotboost is offline   Reply With Quote
Old 09-24-2008, 01:44 PM   #18
Thanks for the reminder!
Thanks for the reminder!!!!!!!
sssalas is offline   Reply With Quote
Old 09-28-2008, 12:35 AM   #19
Originally Posted by ehoez View Post
How often do you REALLY empty/clean your Air Compressor?The book says every day.... but who really does it?
I highly recommend to completely drain your tank daily to prolong the life of your investment. If a different drain valve (as recommended on this thread) makes it easier that would be a great idea to make it EZ for you. Once rust begins it is very difficult to resolve. Disassembly or tank replacement is no fun while the potential for tank rupture remains possible as the rust thins the tank over time. The typical air compressor manual usually recommends that the tank be checked for tank integrity routinely to cover their liability with a pressurized device.
aggreX is offline   Reply With Quote
Old 10-01-2008, 08:52 AM   #20
When I Remember, Which Is About Every Other Month.
Bowhunterman is offline   Reply With Quote
Old 10-02-2008, 09:31 PM   #21
Commercial Flat Roofing
OK, OK After I'm done using it
What about the PEX!!!!!
Talos4 is offline   Reply With Quote
Old 11-03-2008, 08:02 AM   #22
I ran PVC from the basement to the garage and out to the backyard, then I installed ball valves so I can direct air where I need it. I just take a small hose and the tools I need to the area I need. Dont have to drag the compressor!
Maybe he did the same thing.
JCAHILL4 is offline   Reply With Quote
Old 11-03-2008, 08:16 AM   #23
RippySkippy's Avatar
Um...you're running compressed air through PVC? The convince isn't worth the risk. I know it's done...but not worth it.
Read down through this document....http://www.osha.gov/dts/hib/hib_data/hib19880520.html
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 11-03-2008, 02:58 PM   #24
Whooops!
ABS, NOT PVC. Sorry that would have been a big problem.
Thanks for the correction
Old 11-11-2008, 11:36 PM   #25
Originally Posted by barnyard05 View Post
I was thinking about trying one of these automatic drainers. I get tired of crawling on the floor and reaching my hand under the compressor to drain it. This looks like it might work. The only problem I see is the 145psi tubing that comes with it. I have a 165 psi compressor. Maybe I could find better tubing for it. I haven't decided whether to try it or not, but for about $10 it might be worth a shot. Has anyone tried this?
http://www.harborfreight.com/cpi/cta...emnumber=46960
I tried one of those a few years ago. Couldn't make it work right. Took it back.
sv9779 is offline   Reply With Quote
240v Air Compressor to 120v help ruacoltsnut General DIY Discussions 10 11-11-2010 04:05 PM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
Bad compressor, and coil question... Undepelo HVAC 24 06-13-2008 01:28 AM
Fridge compressor convert to air compressor? jogr Appliances 1 04-24-2008 01:10 PM
Air Compressor Timer 69-er Electrical 7 10-02-2007 03:40 PM
