How Much Faster Rotary Hammer Vs. My Hammer Drill - Tools - DIY Chatroom Home Improvement Forum
Old 01-03-2013, 06:53 PM   #1
How much faster Rotary Hammer vs. my Hammer Drill
I have a 7.5 amp motor hammer drill. It takes me approximately 45 minutes to drill a 3/8" hole 2.5" deep into some beach stones.
My question is . . .
How much less time would it take me to drill the same hole using a 5.2 Amp SDS Plus Rotary Hammer, 2920 blows per minute?
TIA,
Kurango
P.S. It only takes a few seconds to drill same hole in concrete, using my hammer drill.
kurango is offline   Reply With Quote
Old 01-03-2013, 07:17 PM   #2
Rewards Points: 558
Get the drill, a stop watch and time yourself, and then you will know the answer.
epson is offline   Reply With Quote
Old 01-03-2013, 07:24 PM   #3
bbo
2.5 inches?
try a concrete chain saw.
or an actual masonry bit.
bbo is offline   Reply With Quote
Old 01-04-2013, 10:34 AM   #4
I have the stop watch, that's how I figured the time it took for the hammer drill.
I am trying to figure out if it is worth my wild to buy the rotary hammer.
I have been using a Bosch blue granite hammer drill bit, drilling slow, in water, so I won't wear out the bit.
Come on guys, you can give me some better educated guess answers!
Just tell me . . . for example
It will cut your time by approximately 10 minutes? or It will take you approximately 75% less time with a rotary hammer?
Old 01-04-2013, 10:42 AM   #5
Rewards Points: 5,974
I really don't know the answer but maybe rent the rotary for 1/2 day to see. Let us know what you find out.
Old 01-04-2013, 10:47 AM   #6
Rewards Points: 13,694
Never took the time to time it but I know for a fast a My Bosch Bull Dog will out drill a hammer drill everytime.
CPO Tools has them on sale.
Plus The bull dog can be use as a chisle for things like busting out tile.
PaliBob (01-04-2013)
Old 01-04-2013, 01:57 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
joes right.. i dont mess around with hammer drills unless i have to drill one hole thats 1/4 diameter. anything bigger i use our hitachi sds hammer.. it drills 1" holes into 90 yr old rock hard concrete like its butter
woodworkbykirk is offline   Reply With Quote
Old 01-04-2013, 02:02 PM   #8
I use a older German made bosch 1224 bulldog. I got my friend, the mechanic( who now works for the local water/sewer company, a hitachi d handle rotary. The bosch is a little more refined BUT I can't believe how hard those Hitachis hit! Blows the bosch away. Very fast drilling and/ or chiseling.
toolaholic is offline   Reply With Quote
Old 01-04-2013, 02:23 PM   #9
I have to go to the way-back machine for this one since I don't use hammer drills that often anymore. But back in the early 80s when I was working as a CATV installer and using a normal Milwaukee hammer drill on a daily basis, I would occasionally rent a rotary hammer drill if I knew I was going to be drilling numerous larger holes (5/8 to 1") through concrete or hard brick. It was a night-and-day difference. The rotary hammer would just eat through stuff. I would have bought one but they were crazy expensive back then.
wrongdave is offline   Reply With Quote
Old 01-04-2013, 02:44 PM   #10
http://www.cpotools.com/bosch-11255v...tml&carousel=8
Old 01-04-2013, 06:29 PM   #11
What I am hearing is . . .
hammer drills are antiquated so no one here ever uses one, so no one can tell me if it would make much of a difference.
No one ever has a reason to drill a 3/8" (larger or smaller) hole 2 1/2" deep in solid rock, so no one knows?
I do appreciate the better answers.
Thanks, Kathi
Old 01-05-2013, 05:40 PM   #12
I'd go to Home Depot, purchase the Bosch Bull Dog, appropriate bit, and try it yourself. If it works then keep the rotary hammer and if it's not to your liking then return it.
c-low is offline   Reply With Quote
Old 01-05-2013, 06:19 PM   #13
Thanks, Kathi
That's not what I hear at all. What I hear is the rotary hammer is a lot better.
Old 01-05-2013, 06:23 PM   #14
I've got limited experience with both types of drills but my neighbor has an arsenal of tools which he is always willing to lend out to me. I borrowed the Bosch Bulldog to drill a dozen holes in concrete and blew thru the holes absolutely quicker than the corded hammer drill.
Old 01-06-2013, 08:50 PM   #15
We call drills with hammering action a hammer drill. A chipping machine with the option to bore holes is called a rotary hammer. It all comes down to BPM, tool weight, and quality of the machine itself. The answer your looking for can only be had in a head to head comparison. My suggestion would be to go to YouTube and check out some videos on the machine you're interested in.
Good luck.
Carreiro is offline   Reply With Quote
The Following User Says Thank You to Carreiro For This Useful Post:
PaliBob (01-08-2013)
Rotary hammer drill KJKerns3 Tools 14 04-11-2012 04:24 PM
Removing tile; electric tile stripper or rotary hammer? mackaz Flooring 0 07-21-2011 06:22 PM
Can Rotary Hammer be used in this case ? jusko Plumbing 3 04-24-2011 09:25 AM
hammer drill vs. drill/driver wombosi Tools 10 05-12-2008 09:40 AM
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 07:26 PM
