Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 04-12-2011, 01:10 AM   #1
Question
how do you take circles out of hole bits??
when you use a hole bit and the wood circle stays inside, how the heck do you take it out???
scratching my head
Old 04-12-2011, 01:16 AM   #2
never mind, i got it. you push the pilot bit in through the threaded hole once you take it off the arbor... DUH !!
Old 04-12-2011, 07:51 AM   #3
Household Handyman
That will work. Starting at some size, yep I forget, there usually are two slanted slots made into the sides which I use a small screwdriver to remove the wood circle. As you have found out, on the smaller hole saws you will need to remove the drill bit or arbor to remove the wood plug.
The Following User Says Thank You to Thurman For This Useful Post:
amakarevic (04-12-2011)
Old 04-12-2011, 12:23 PM   #4
On thicker materials, a door as an example, drill a bit over halfway from one side, then finish it from the other side; not that it always works out in your favor, but sometimes it helps keep the waste from being jammed into the bit as far, and it will leave a cleaner hole.
The Following 2 Users Say Thank You to DexterII For This Useful Post:
amakarevic (04-12-2011), DangerMouse (04-12-2011)
Old 04-12-2011, 05:12 PM   #5
nap
You talking to me?
nap's Avatar
if you do not need a very accurate hole, you can also wobble the hole saw as you drill/cut. It will cut the plug so it is smaller than the inside dimension of the holesaw.
Old 04-12-2011, 05:24 PM   #6
waterman1971's Avatar
I always thought those slots were used for stabbing yourself in the palm of the hand.
waterman1971 is offline   Reply With Quote
Old 04-12-2011, 08:58 PM   #7
nap
You talking to me?
nap's Avatar
work good, don't they??!!!
just wait and see how exciting it is when you have a screwdriver stuck in there and accidentally hit the trigger (of course the proper thing to do is unplug the drill or remove the battery which I am sure we all do just so that won't happen)
hole drill bits for cement board amakarevic Tools 1 04-12-2011 09:12 AM
Huge hole in foundation texasgolfer Building & Construction 2 01-07-2011 06:55 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 10:26 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
