Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 07-21-2012, 09:52 AM   #1
How do I fix drain cock on Husky 30-gallon compressor?
I have a brand new Husky 30-gallon compressor, and it seems the drain cock won't close. I try to turn it counter clock wise and it keeps unscrewing and unscrewing until it pops out of the bottom and of course never closes off the escaping here.
This blows. I've got paint drying in my paint gun trying to fix this......
What am I missing here??
noone is offline   Reply With Quote
Old 07-21-2012, 04:17 PM   #2
Replacement drain cocks at Home Depot were $3.50. Problems solved.
Old 07-21-2012, 09:09 PM   #3
Tom Struble's Avatar
glad you got your cock problem straightened out and so cheaply too
Tom Struble is offline   Reply With Quote
Old 07-22-2012, 01:49 AM   #4
In a little over my head
Spend $12 on a ball valve and a few brass fittings and you'll like it even better.
Glad you're back in business.
ratherbefishing is offline   Reply With Quote
Old 07-22-2012, 01:19 PM   #5
jschaben
+1 on this, add a couple of elbows and a length of pipe and bring it to the front or side and you'll love it
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 07-22-2012, 02:36 PM   #6
Yup. Great minds think alike.
Old 07-24-2012, 12:27 PM   #7
here's a pic to go along with the suggestions to extend a ball valve out to a reachable location.
silversport is offline   Reply With Quote
The Following 2 Users Say Thank You to silversport For This Useful Post:
jschaben (07-24-2012), ratherbefishing (07-26-2012)
Old 07-25-2012, 07:36 PM   #8
Master General ReEngineer
Bondo's Avatar
Ayuh,.... 'n another option is a cabled spring loaded drain, for a heavy truck with air brakes,...
1/4" pipe, screws right in, 'n hang the cable...
The Following 2 Users Say Thank You to Bondo For This Useful Post:
jschaben (07-25-2012), ratherbefishing (07-26-2012)
Old 07-31-2012, 01:14 PM   #9
This is good for everyday use. If you don't use your compressor daily, you need a drain that can be left open. Even thou the compressor is not running daily it will form condensation from temp change with air in it. The cable drain is good for condensation drop thou.
Hardway is offline   Reply With Quote
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 07:52 PM
Craftsman 3 gallon 1HP air compressor model #921.153101 PSD Appliances 1 02-13-2011 11:51 AM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 08:38 AM
Water Heater discharging water from drain cock. Rudy68 Plumbing 12 06-15-2010 10:58 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
