Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 06-29-2012, 04:43 PM   #1
How can I remove broken bit from magnetic bit holder?
I was using a bit extender with magnetic bit holder. When I started using it, I was amazed at how powerful the magnets were--it was tough to get a bit out. Now I've got a broken bit and can't get a good grip to pull out what's left. Any thoughts on what to do? (Temporarily) neutralize the magnet--is that even possible? drill out the broken bit? Thanks.
tabatt07 is offline   Reply With Quote
Old 06-29-2012, 06:38 PM   #2
Persona Non Grata
VIPlumber's Avatar
Clamp the extender in a bench vise and use a pair of pliers to tug the broken bit straight out. By the by how exactly break your bit, and what kind were you using?
VIPlumber is online now   Reply With Quote
Old 06-30-2012, 07:12 AM   #3
Thanks for the response. The bit broke flush such that I can't grab it with pliers. I was using a hole saw as part of a DIY home networking project. I let it get too hot and then it snapped. I can live with that but I'd really regret having ruined the extender.
Old 06-30-2012, 08:13 AM   #4
Tom Struble's Avatar
maybe epoxy or super glue a small nail head to whats left of the bit?need to be careful not to glue everything together
Tom Struble is offline   Reply With Quote
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
PaliBob (06-30-2012), Thurman (07-31-2012)
Old 06-30-2012, 11:43 AM   #5
Tool Geek
PaliBob's Avatar
If all else fails, here is one type replacement
or you can get rid of the magnet
Or even one with a right angle
& Stay Safe
.....Bob Lavery
Old 06-30-2012, 02:43 PM   #6
or maybe a stronger magnet?
The Following User Says Thank You to Tom Struble For This Useful Post:
ratherbefishing (07-30-2012)
Old 07-01-2012, 07:11 PM   #7
or spend 2 dollars on a new apex....
sevenlol is offline   Reply With Quote
The Following User Says Thank You to sevenlol For This Useful Post:
kwikfishron (07-01-2012)
Old 07-01-2012, 09:13 PM   #8
the Musigician
DangerMouse's Avatar
Vise it and hit it with a torch, the magnet will die and let the bit go, and the glue holding the magnet in will burn away and the magnet will fall out too. Glue in new magnet and you're good to go.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 07-30-2012, 12:59 AM   #9
Or use a screw extractor
epson is offline   Reply With Quote
Repairing a broken settled cement slap to repair broken tiles Dtlsr42 Flooring 0 02-20-2012 02:43 PM
How to Remove Broken Piece from Showerhead Pipe Cindy_Home Plumbing 14 12-27-2011 04:36 PM
Trying to remove flush mount finish nails pms1228 General Discussion 18 03-15-2011 10:42 AM
How do I remove a piece of broken PVC? Geoffro Plumbing 3 04-21-2007 09:59 AM
